Author Topic: HBV valve MV6 V6  (Read 4518 times)
Re: HBV valve MV6 V6
« Reply #15 on: 31 October 2012, 16:19:33 »
Third hose goes to connector at back of coolant bridge.
opeldåre
  • Uppsala Sweden
    • Opel Omega MV6 1996
    • My page on Garaget
« Reply #16 on: 31 October 2012, 16:53:50 »
Ok thank you for all your help.
I solved the pump problem and it was the hose from the expantion tank that was plugged. And the pump didnt have any power so I connected it thru a switch on the dash.
The temperature i the car became much better.
According the HBV I found that this two models of HBV is used in Omega B V6 so it was the right HBV valve in the car.
Once again thank you for all your help in this matter.
« Reply #17 on: 31 October 2012, 17:13:27 »
