Author Topic: radio reception / HRW  (Read 1565 times)
« on: 01 November 2012, 22:52:39 »
I want to sort the radio reception out when I have the HRW on. At the moment, switching the HRW while the radio is on, renders the radio un-listen-able. The aerial box of trick is under the parcel shelf, how's this connect to the HRW? Is it likely to be just cleaning connections? Am I in danger of pulling connections from the HRW itself?
TIA
Re: radio reception / HRW
« Reply #1 on: 01 November 2012, 23:00:28 »
TIA
IIRC the connections are behind the O/S "C" panel trim. The two mini spades in pic
« Reply #2 on: 01 November 2012, 23:09:45 »
Thanks Rob ........ I kinda knew you'd have a picture  ::) ::)
Weather dependant, I'll try to look sooner rather than later, especially as winter is around the corner - assuming I use it over the winter when there's a 4x4 on the drive!  ;)
