Author Topic: ABS  (Read 2465 times)
martin341
  • Finland
  • I do my own stunts.
    • '00 3,0 MV6, '00 2,5 V6
ABS
« on: 02 November 2012, 17:00:20 »
Hei!
Once again i´m looking for advice. Question is: Can one fit a pre-facelift Omega ABS-control unit(the "Brain") in facelift Omega? Are they same?
And where can i find a wiring diagram of ABS for facelift Omega. If i am very lucky(probably noooot :'() then there is only a broken wire or something but i do not want to go "blind" and rip the whole car apart. So if anyone can help-> PM.
Cheers,
Martin
Re: ABS
« Reply #1 on: 02 November 2012, 17:15:58 »
Early pre mini face lift will be different, they're only 3 channel ABS systems whereas the facelift is 4 channel. Miniface lifts are 4 channel systems too, but don't know if they the same as face lift though  :-\
Re: ABS
« Reply #2 on: 02 November 2012, 18:24:09 »
Will be OK, obviously same spec from donor ;)
martin341
  • Finland
Re: ABS
« Reply #3 on: 02 November 2012, 21:21:29 »
Thanks for reply!
So if i take the ABS-box from lets say 97-98 Omega its plug´n´play? And how about TC and cruise control, does these features have to be in the car that i take the part from or it doesn´t matter?
Cheers,
Martin
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: ABS
« Reply #4 on: 02 November 2012, 22:56:49 »
 cruise control on 97-98 is cable/servo operated.  on dbw its ecu controled.
Hoof'land storeman.
Re: ABS
« Reply #5 on: 03 November 2012, 20:22:15 »
Thanks for reply!
Cheers,
Martin
Borderline. If last LETTER of VIN is W ot X, the ABS unit should be interchangable, assuming the engine is same.
martin341
  • Finland
Re: ABS
« Reply #6 on: 06 November 2012, 14:36:32 »
Hei,
Is this the right part number for me: Bosch 0273004206
Cheers,
Martin
