Author Topic: Computer advice..boot manager  (Read 1324 times)
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
« on: 02 November 2012, 23:27:21 »
 Hi all you buffs ;)
I have two computers, one with Windows 7 64bit on one drive, (SATA) and Windows seven 32bit on another drive (IDE). When I boot up, I get a boot manager screen, and can choose which OS to boot from. Perfect
On my second computer, I have a SATA drive with Windows 7 64 loaded, and a second drive (IDE) with Windows XP loaded. Both systems work fine. However, when I boot up, I do not get a boot manager screen, giving me the option of booting into Windows 7 or XP.
Obviously, going to BIOS and changing boot priority works fine, but this is a pain. As computer one shows an option screen, why does computer two not display the same.
I have been into the Control Panel route to boot manager, and it only lists Windows 7. No sign of XP. Is this an XP/7 clash. I seem to remember a while back, having two XP drives, I was given the option of which drive to boot from.
Sorry this is long winded, but it explains exactly what is happening :y
Tony
Re: Computer advice..boot manager
« Reply #1 on: 03 November 2012, 02:27:26 »
Easy solution - use a 3rd party boot manager.
A free (good) one is GAG - you can download it from here
HTH  :y
Martian
« Reply #2 on: 03 November 2012, 09:50:45 »
Because Win XP wasn't present when Win 7 was installed.
Plomien
  • Swansea
    • Landrover Freelander TD4
« Reply #3 on: 03 November 2012, 10:02:45 »
you can adjust the boot.ini file but I expect that is what the program dbug suggested does
« Reply #4 on: 03 November 2012, 20:29:55 »
This is what I would do.  I have a natural distrust of programs downloaded from net that require admin rights ::)
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
« Reply #5 on: 04 November 2012, 16:48:24 »
Thanks for replies....now sorted, via your advice :y
So Mark, for future reference, is it a case of loading the 'older' windows system first, then the updated version ;)
Tony
« Reply #6 on: 04 November 2012, 19:03:37 »
Tony
Generally that works better, as the "newer" one should be more aware of the older one.
Though XP doesn't really play nicely with anything. Lets face it, its nearly 12yrs old, and should be retired. MS are pulling the plug, at last, in 2014 IIRC
Martian
« Reply #7 on: 04 November 2012, 21:07:03 »
Tony
In the case of Windows, that is how it's done.
If you want to start "mixing & matching" though (ie, Windows, OSX, *nix, etc), then the above rule won't necessarily apply.
