Author Topic: poor radio reception when heated rear screen on  (Read 1638 times)
doz
  • Southampton
  • LC,GSi Carlton,Omega Elite
« on: 06 November 2012, 11:24:30 »
As the title. This morning a heavy frost on car. Flicked on rear demist and radio goes pants. 2013 headunit. 2000 X plate FL
    • 530D M Sport, 330i Coupe
Re: poor radio reception when heated rear screen on
« Reply #1 on: 06 November 2012, 18:15:15 »
Worth taking the parcel shelf out and checking all connectors to the aerial amp are clean and good, might also be worth cleaning the inside of the glass.
« Reply #2 on: 06 November 2012, 18:38:23 »
2 things, as VXL V^ says.
Clean screen on the inside, but don't damage the element, and check 0v connections, which may have a higher PD across them with the extra current.
« Reply #3 on: 06 November 2012, 18:47:12 »
Visually check the element using a magnifying glass along its whole length. If the element is slightly damaged the current for the heating "may" be arcing across the damage, so upsetting the FM reception side of the element. Damage "may" be repairable using conducting paint applied very carefully.
