Author Topic: 2.6 -> 3.0  (Read 2951 times)
Re: 2.6 -> 3.0
« Reply #15 on: 08 November 2012, 15:22:04 »
Just checked the heads on my year 2000 3.0 breaker and it has the holes for the coil packs. So,does that mean the heads would be ok to fit to a 2.6 and/or a 3.2 ?  :-\
That depends if the valves and combustion chambers are the same size. I can't remember if they are. You might end up changing the compression ratio otherwise.
Re: 2.6 -> 3.0
« Reply #16 on: 08 November 2012, 15:25:31 »
Could it change it enough to cause a problem :-\
Obviously too high and things break, too low and the car becomes gutless porridge  :-\
