Author Topic: Oof slow?  (Read 2674 times)
Re: Oof slow?
« Reply #15 on: 08 November 2012, 17:51:45 »
...while on the other hand, at least we now know what and where the problem is.
Plumber fitted a press pack, with a pressure gauge, in an attempt to force air out of the system after fitting a new boiler.
The gauge reveals that water is escaping.
Re: Oof slow?
« Reply #16 on: 08 November 2012, 17:55:28 »
Mine slowly bleeds down too (after I switched from an old vented system to modern combi pressurised system) .. I'm assuming it's in the floor as I don't see wet anywhere and, therefore, I'm ignoring it like any good house owner.. ;D
Re: Oof slow?
« Reply #17 on: 08 November 2012, 18:53:06 »
I turned the heating up full blast and fealt for warm patches with bare feat on the ground floor.
I was able to map out the pipe work by walking around. A warm area was a obvious radiating out from a box section where the water pipes come down from upstairs.
Luckily there is a service hatch. Once removed steam could be seen rising.
Laminate floor up tomorrow.
Although she's out at the moment. So I may pile into it shortly. ...or I may go back to bed. ;D
Re: Oof slow?
« Reply #18 on: 08 November 2012, 19:00:55 »
Back to topic, images server, being on shared hosting with a 3rd party company, its out of our hands, and more prone to glitches/slowdowns/SNAFUs.
Re: Oof slow?
« Reply #19 on: 08 November 2012, 19:06:22 »
Yes it did "look" like images, as all the text was present, but little else.
But switch wifi network and all was well. Should have tried that first.
Appologies. :)
Re: Oof slow?
« Reply #20 on: 08 November 2012, 19:09:05 »
Appologies. :)
Could be the DNS wasn;t working too well. O2 do have a bit of a reputation for unreliable DNS (shame, as the services isn't too bad otherwise).
Or a images server glitch, resolved by the time you wedge yer ass out of bed, and onto another router...
Re: Oof slow?
« Reply #21 on: 08 November 2012, 19:28:35 »
Mmmno, I can switch networks from bed. It's not a problem. ;) ;D
Re: Oof slow?
« Reply #22 on: 08 November 2012, 19:34:02 »
Your network clearly isn't complex enough ;D
