Author Topic: Car Insurance  (Read 4408 times)
file28
Re: Car Insurance
« Reply #15 on: 28 April 2008, 13:41:02 »
its to stop the v6 overheating when switching off as the temps still rises cos there is no air flowing through it s called thermal something or other someone on here should know the correct term
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
Re: Car Insurance
« Reply #16 on: 28 April 2008, 13:59:56 »
Elite is fine, cant find fault with it apart from a nick in the paint work.
There is a pump/fan noise coming from the from, the guy said it does it on start up and switch off for 5/10 seconds.
I thought it might be the selfleveling pump, but my mate had a vectra and it sounds like the noise his was making, he replaced it and it still made the same noise.  It came to that it was some sort of fan than was something to do with cold satrting or something.
Maybe someone knows the true reason of the pump/fan noise.
not sure but there is some sort of elec water pump on the v6 vec may be the same on the v6 mig
could be secondary air injection pump. nothing to worry about just pump designed to get airflow to cats and bring them up to temperature quicker. you can unplug it if you dont want the noise. it won't do any damage to your motor, but does sound like a jet engine for a few seconds hehehe
that said, this noise will only occur on startup, not switchoff
« Last Edit: 28 April 2008, 14:02:34 by ilovemyelite »
PM with your requests.
Andyb
  • Lincoln
Re: Car Insurance
« Reply #17 on: 28 April 2008, 16:02:08 »
As above
its the same as a vectra will last longer the colder the cats are
