Author Topic: Garage Floor  (Read 3896 times)
ians
  • Reading
Garage Floor
« on: 28 April 2008, 17:09:21 »
Intend to paint my new garage floor soon (concrete poured 2 months ago)
Does anyone have experience of this?
I was going to use a first coat diluted with white spirit, effectively as a primer, and then a second coat neat.   I can't face all that work on hands and knees so I intend to get a roller extension with masonary sleeve.
Anyway - I'd much appreciate advice from anyone who has been there before.. :y
FRE07962128
Re: Garage Floor
« Reply #1 on: 28 April 2008, 17:15:34 »
Yes I once painted my garage floor with red floor paint by just following the advice on the tin.  If I remember correctly the first coat I thinned, and then the second (final) coat was unthinned.  It was all put on with a large brush, but I suppose a roller would do the job.
However, on new ( highly porous) concrete the first and second coats would be best thinned and then a final third coat unthinned on top.
In terms of thinning the paint with white spirit it does depend on wether or not the paint is oil or water based.
All the best with this very satisfying job :y ;)
« Last Edit: 28 April 2008, 17:17:42 by FRE07962128 »
Debs.
Re: Garage Floor
« Reply #2 on: 28 April 2008, 17:20:21 »
My gut feeling would be to PVA (purely for surface adhesion reasons) the bare concrete with a 'strong' solution with water and be sure to let it dry thoroughly before starting on the floor-paint.....experts will doubtless follow with opinions on it....`just what I`d probably do!  ;)
Re: Garage Floor
« Reply #3 on: 28 April 2008, 17:22:12 »
My first few thoughts are as follows:
1) 2 Months is not that long for a conrete slab to fully dry.
2) Use a stabilising solution first as this will help bind the as yet unproven concrete surface and help the paint adhere.
psl
  • New Malden (Surrey)
Re: Garage Floor
« Reply #4 on: 28 April 2008, 17:28:33 »
I wouldnt go for a pva primer as its water based and the pait spirit based, a spirit based primer would be ok though.
Re: Garage Floor
« Reply #5 on: 28 April 2008, 17:35:42 »
Lizzie is bang on. I know cos that's not what I did. I should've thinned the first coat as Lizzie said, but, as I didn't, it's now lifted in various places. :(   ::)
Re: Garage Floor
« Reply #6 on: 28 April 2008, 17:35:51 »
I woudn't use PVA as its good on plaster etc which is mega absorbent but, not nearly as effective on conrete plus PVA is not as stable as some may think!
As said, a specific stabilising solution such as:
http://www.screwfix.com/prods/14511/Paint/Specialist-Paints/Stabilising-Solution-5Ltr;jsessionid=GNQD1BV1R4MHCCSTHZOSFFA
And use a roller, the finish is much better, easier to clean down and nicer to apply.
Re: Garage Floor
« Reply #7 on: 28 April 2008, 17:39:51 »
Thats more to do with the stability of the concrete base....you need to bind it because it will be dusty not matter how much you try to clean it up.
ians
  • Reading
Re: Garage Floor
« Reply #8 on: 28 April 2008, 18:19:37 »
TY all.   The paint is spirit based (tin definitely says clean brushes with white spirit).  I also know it says leave new concrete for 8 weeks.  Don't want to be impatient but need to move stuff back in there.
I don't think (its at home) that it mentions priming/sealing/ dilute coat etc.  I just remember last time I did this on a relatively new slab that the suction on the first coat was massive and the coverage was awful.  (probably didn't stick that well either).
I'll check out Screwfix - there's one just up the road if needed.
Cheers,
Ian
Re: Garage Floor
« Reply #9 on: 28 April 2008, 18:22:40 »
Previous owner painted my garage floor (no idea what he used) but if you park a wet car on it, the paint sticks to the tyres and gets pulled up when you subsequently move it.
I have no idea what or how it was applied in this case but the message has to be to make sure it's stuck to stable concrete and properly prepared.
Jay w
  • Plymouth/Poole
  • omega gone
Re: Garage Floor
« Reply #10 on: 28 April 2008, 18:33:21 »
if you look at the mainstream stuff you can buy at DIY stores you will find they recommend a sealer.
When i did mine i sealed it first (keep the garage well ventiliated) and then did the first coat watered down, the second and third were full strength.
I get the issue where i have to let the tyre cool before parking the car in there, if they are up to temp and i park the car in there it will life the paint  >:(
it does tidy it up and makes it less dusty though
Re: Garage Floor
« Reply #11 on: 28 April 2008, 18:38:37 »
A mate of mine did his with an epoxy based paint, IIRC. It was not cheap but it did last well. Then again, he also had plasterboard dry lining and coving in his garage...  :o Coving FFS?
Jay w
  • Plymouth/Poole
  • omega gone
Re: Garage Floor
« Reply #12 on: 28 April 2008, 18:39:23 »
i have about 3000 white tiles to go up in the garage.....when i get the time
ians
  • Reading
Re: Garage Floor
« Reply #13 on: 28 April 2008, 18:40:49 »
chandelier too?
ians
  • Reading
Re: Garage Floor
« Reply #14 on: 28 April 2008, 18:43:14 »
according to my building regs approval I also need to redo the ceiling with f(*&*& expensive celotex insulation and plasterboard.   (I'm converting what was a carport into proper garage - there is a room above , hence the insulation requirements.)
