Author Topic: Well I'll be.  (Read 3886 times)
doz
  • Southampton
  • LC,GSi Carlton,Omega Elite
Well I'll be.
« on: 12 November 2012, 23:13:10 »
Just did a round trip to Cheltenham from Southampton. Was doing the unofficial, official cruising speed in the Omega (3.0lt auto) and bugger me if the darn thing didn't return 32MPG and that's calculated by filling the tank back up when I got home. Really comfy too, however I think I maybe able to turn the stereo down a little if I fixed the wheel bearing  :oops:
Re: Well I'll be.
« Reply #1 on: 13 November 2012, 12:52:43 »
We've just returned from a trip to Wales. Filled the tank and the light came on after 378 miles. Not sure if that's good or not as I've no idea how much fuel the Omega tank holds.  :y
I reckon I could squeeze another twenty miles at a push. :y
« Last Edit: 13 November 2012, 12:54:46 by Opti »
2boxerdogs
Re: Well I'll be.
« Reply #2 on: 13 November 2012, 13:14:58 »
Hi, fuel tank is 75 litres= 16.5 gallons light usually comes on after using 60 litres, so 30mpg approx for 378 miles that is also what my 2.6 manual does.
Re: Well I'll be.
« Reply #3 on: 14 November 2012, 10:18:10 »
Something wrong with my car , ill be lucky to get half that mpg in mine  >:(
Re: Well I'll be.
« Reply #4 on: 14 November 2012, 10:28:39 »
check your coolant temperature sensor and exhaust system for holes.. :y
Re: Well I'll be.
« Reply #5 on: 14 November 2012, 11:39:13 »
Is that the one under the back of the plenum cem  :-\
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Well I'll be.
« Reply #6 on: 14 November 2012, 11:52:58 »
No, that single wire sender is temp gauge only,the one you are looking for is the injection temp sensor,I don't recall where it is though as My Mig has been gone a while :-\
other rides
Re: Well I'll be.
« Reply #7 on: 14 November 2012, 11:59:55 »
Now im lost  ;D :-[ :-\
Injection Temp Sensor hmm i never heard of that one , maybe Rob has a picture  :)
« Last Edit: 14 November 2012, 12:02:42 by EMD »
Re: Well I'll be.
« Reply #8 on: 14 November 2012, 12:10:49 »
I seem to recall the ECU temp sensor (2-wire) is right beside the gauge temperature sender (1-wire) on the coolant bridge
henryd
  • west cornwall
Re: Well I'll be.
« Reply #9 on: 14 November 2012, 15:02:46 »
that'll be the one,mind you not worth changing unless known to be faulty.
other rides
brendan1983
  • Hampshire
    • Omega CDX Saloon
Re: Well I'll be.
« Reply #10 on: 14 November 2012, 17:09:09 »
On a long trip - Fareham to New Quay (in Wales) I've done the round trip on one tank before...  490 miles (ish)
Trip computer showed about 33mpg
2003 CDX & Yamaha Thunderace
Re: Well I'll be.
« Reply #11 on: 14 November 2012, 18:53:05 »
http://www.omegaowners.com/forum/YaBB.pl?num=1282153709/0
sorry for the late answer :-[ but thats for 2.0 its in the v valley , "blue one" ;D :y
« Last Edit: 14 November 2012, 18:55:49 by cem »
Re: Well I'll be.
« Reply #12 on: 14 November 2012, 19:09:11 »
sorry for the late answer :-[ but thats for 2.0... for 3.0 its in the v valley , "blue one" ;D :y
Re: Well I'll be.
« Reply #13 on: 14 November 2012, 19:19:58 »
I will check , would it not throw a code up  :-\
Re: Well I'll be.
« Reply #14 on: 14 November 2012, 19:47:27 »
normally you can check it via tech 2..  but must be completely donald for the ecu to light eml I think..
