Author Topic: wiper problem  (Read 2358 times)
Omega Martin
wiper problem
« on: 12 November 2012, 23:30:42 »
    Hi all, got me some wiper trouble. I'm finding that my wipers won't work on the first position, intermittent setting, also they fail to self park, can anyone help ? (2.5td)
Cheers
Omega Martin
Big_Al
Re: wiper problem
« Reply #1 on: 13 November 2012, 13:35:08 »
Tall yellow relay in triangle fuse box under the bonnet  battery side  :y
Just had exact same trouble  . . . replacement relay   A1   again  :y :y :y
presume diesel is the same  :-\ :-\
Re: wiper problem
« Reply #2 on: 13 November 2012, 13:42:18 »
I take it I sent the correct relay then Al ?  :).............may well have another if the OP needs one. :y
Big_Al
Re: wiper problem
« Reply #3 on: 13 November 2012, 13:44:49 »
Sent you a PM   . . . not having much joy on my other thread though  :( :( :( :(
Re: wiper problem
« Reply #4 on: 13 November 2012, 13:56:39 »
Hopefully one of the experts will have a look and have an idea how to proceed. :y
Re: wiper problem
« Reply #5 on: 13 November 2012, 15:00:51 »
.   . . . not having much joy on my other thread though  :( :( :( :(
multiple threads on the same fault just causes confusion .......  ;)
The self park is a switch within the wiper motor, could be that that is goosed. By rights you can't get to it, so you need a new/A N Other wiper motor.  ;)
Big_Al
Re: wiper problem
« Reply #6 on: 13 November 2012, 16:07:45 »
Surely it  is worth trying the relay first. It was the problem with mine .
Appolgies for the multiple thread inclusion  earlier .I  now  understand  this could cause confusion  :-[
« Last Edit: 13 November 2012, 16:15:55 by Essex Big Al »
Re: wiper problem
« Reply #7 on: 13 November 2012, 17:53:01 »
Surely it  is worth trying the relay first. ......
Yes, if you have one to hand. Still doesn't change where the self park switch is though.  ;) ;)
symes
  • oxford
    • R reg 940 volvo
Re: wiper problem
« Reply #8 on: 13 November 2012, 18:15:28 »
did you spray electrical contact spray into switch? that might help-dirty contacts in switch?? only a guess mate
