Author Topic: gearbox problem  (Read 7520 times)
moonshine
  • frizington,cumbria
    • 2.2 cd auto
gearbox problem
« on: 13 November 2012, 11:31:03 »
Hi Guys,
         The car drives perfect except for the gearbox,when driving it only holds 3 gear for a short time before changing,when you get to a hill it will change into 2nd pick up speed change into 3rd and virtually straight away change into 4th,because we are still going up the hill it`s too high a gear so it changes down to 3rd and then straight to 2nd.
I then have to hold 2nd to stop it changing too often.Any idea`s.
Re: gearbox problem
« Reply #1 on: 13 November 2012, 11:46:42 »
Hi and Welcome  :)
Firstly, best to ask such questions in "Omega General Help" as more of "them that know" read there than here.
Trouble changing gear in the auto can often be caused by low fluid, first thing to do is to check the level PROPERLY.
This link :  http://www.omegaowners.com/forum/index.php?topic=90508.0
tells you how ..it is MOST important that the gearbox is warm, level AND ENGINE RUNNING WITH PARK SELECTED, any other combination will give a false reading, and usually ends up with too little fluid in the box.
It's by far the cheapest "fix" and even if it is NOT the fix .. it rules out low fluid as the cause.
HTH  :)
x25dt
  • Portugal
Re: gearbox problem
« Reply #2 on: 13 November 2012, 11:55:46 »
Hi and Welcome :y
Re: gearbox problem
« Reply #3 on: 13 November 2012, 15:28:49 »
Hi and welcome to oof  :)
flyer 0712
Re: gearbox problem
« Reply #4 on: 13 November 2012, 17:49:37 »
Welcome to the forum  :y
Johnny English
  • Hungary
  • English antitalent
    • 1995. 2.5 V6 LPG manual
Re: gearbox problem
« Reply #5 on: 13 November 2012, 19:49:45 »
Welcome to oof mate and good luck with gearbox!
C20NE - X25XE
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
Re: gearbox problem
« Reply #6 on: 13 November 2012, 20:06:20 »
hi & welcome :y
Re: gearbox problem
« Reply #7 on: 13 November 2012, 20:09:13 »
Welcome to OOF mate   :y
Bucko
  • Newark notts
    • 53 2.2 omega
Re: gearbox problem
« Reply #8 on: 13 November 2012, 20:41:33 »
Welcome to oof :y
Re: gearbox problem
« Reply #9 on: 13 November 2012, 21:38:01 »
Hello and welcome to the forum............ :y
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: gearbox problem
« Reply #10 on: 13 November 2012, 22:23:12 »
Hi and welcome :y :y
other rides
jonnyboyws6
  • grimsby
Re: gearbox problem
« Reply #11 on: 13 November 2012, 22:24:39 »
Welcome to the forum, hope you get the gearbox sorted
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: gearbox problem
« Reply #12 on: 14 November 2012, 01:36:29 »
Welcome bud! :y
Stallion
  • Romford
    • 3.2 Irmscher Elite
Re: gearbox problem
« Reply #13 on: 14 November 2012, 04:26:49 »
Hello And Welcome To OOF Matey!  :y
sandune
  • Essex Southend
    • 2.6 Omega Auto
Re: gearbox problem
« Reply #14 on: 14 November 2012, 11:06:23 »
Hiya welcome to the OOF :y
Page created in 0.029 seconds with 20 queries.
