I did it! -DIS Pack
Started by Lizzie_Zoom, 14 November 2012, 17:30:08
Cav9_4
"Congrats" and well done! :y
Quote from: omegod on 14 November 2012, 18:24:59
Well you live and learn, I didn't realise there was a 3.0 facelift! thought they were all 3.2
No those built in 2000 and I believe up to 2002 were 3.0's.  The 3.2's were a late addition.
Quote from: Lizzie Zoom on 14 November 2012, 17:59:56
Quote from: TheBoy on 14 November 2012, 17:56:16
I'd be inclined to get a decent cheap exhaust from Eternal (about £100 for the 3 pieces).
Not a bad job to change, just be aware the front bolts can shear, needing a drill and a tap set.
Right. Thanks TB. :y
Where do you get those "Eternal" exhausts please?
On egay, search foe eternalcar. There sites are ropey, but they do respond to messages sent early in the day
Quote from: Lizzie Zoom on 14 November 2012, 18:37:47
2001 :)
Quote from: TheBoy on 14 November 2012, 18:39:37
Thanks :y
Quote from: Albitz on 14 November 2012, 18:29:45
Early facelift v6,s were 2.5 & 3.0,then changed to 2.6 & 3.2 - around 2001 iirc.
I probably have to do this dispack change (and stat change) myself sometime in the not too distant future.Got a misfire sometimes on gas and as I have a spare dispack might as well change it to find out if  thats the cause.
..............and to think with mine it all started with a service, a plug lead falling apart, and me trying to repair it, with afterwards starting the engine and running it with a misfire!! ::) ::) ::)
That will teach me not to be so stupid and use my mechanical brain :D :D
Got a spare set of leads too.Thing is do I change them at the same time ? Might see what the old dispack looks like when it comes out and see how lucky I feel that day. ;)
Quote from: Albitz on 14 November 2012, 20:38:58
I would now, with hindsight, replace all at the same time.
My DIS pack was certainly on the way out with or without my spark lead / misfire problem.  Just look at the right hand side of the picture:
Probably caused by water leaking onto it from a leaky scuttle. ;)
symes
I think its heat build up as look were they put the stupid thing!!! >:( silliest most stupid place
Quote from: Albitz on 14 November 2012, 20:50:57
First job to do is check for scuttle leaks after fitment and seal up so you dont have to replace sometime soon again  :)
Its 12yrs old, and done X miles, it probably hasn't done so bad, esp if it was firing a failing lead :y
That said, MV6 is still on its original, so they can last 14yrs/192k
Quote from: TheBoy on 14 November 2012, 21:13:27
Aye , im sure mine was the original as well . Water was dripping onto mine  :) cant see the car lasting another 15 yrs but you never know  ;D
NF
Well done Lizzie, glad you got it sorted, hope the arms soon heal.
Trade Card Holder
