Author Topic: Electrical regs question  (Read 1548 times)
Tony H
  • liverpool
  • Black Elites are luurvley
« on: 17 November 2012, 22:11:06 »
Evenin' all. My daughter has rented out her old house and it needs the electric shower replacing. I am quite capable to do the job but do you need any formal qualifications to do this as the house is occupied by tenants.
TIA
Tony
the alarming man
  • medway kent
    • disco V8
Re: Electrical regs question
« Reply #1 on: 17 November 2012, 23:17:23 »
part p i think :y
« Reply #2 on: 17 November 2012, 23:21:04 »
part p i think :y
I thought that part P covered NEW installations. If Tony is replacing an existing shower, it won't be a new installation ......  :-\ :-\
the alarming man
  • medway kent
    • disco V8
« Reply #3 on: 17 November 2012, 23:34:33 »
not sure as the last person to touch the ring become liable for the install BUT i guess if you have a landlord safety test it will be the guy who does the test
« Last Edit: 17 November 2012, 23:36:12 by the alarming man »
Tony H
  • liverpool
« Reply #4 on: 17 November 2012, 23:48:31 »
part p i think :y
That's what I thought that you can replace existing installations    e.g a socket or a light fitting etc but not to sure if you can replace a shower or something more complexed  :-\
« Reply #5 on: 18 November 2012, 00:00:48 »
Having just replaced a shower for a neighbour, ok ... not in rented place but in a private place... the electrics is simply disconnect 3 wires and reconnect in the new unit ....actually easier than replacing a socket as there is more room to move !!
Now this was a properly installed system .. with ceiling isolator, seperate feed direct from rcb in main distribution box, and using proper T&E, so I don't think regulations apply.
If any part of the supply had needed changing, then different ball game... IMHO .. :)
« Reply #6 on: 18 November 2012, 00:24:32 »
As said, the job is a walk in the park. That's not the issue. Not sure I'd be touching it in a rented house, though.
Do make sure the circuit is correctly rated for the new shower. They come in a variety of powers and the wire might need to be derated depending on where it's run.
Martian
« Reply #7 on: 18 November 2012, 07:59:35 »
As Kevin says, your only concern is that the existing cable is man enough to supply the replacement shower.
Part P does not apply as you are simply replacing "like for like"
Page created in 0.022 seconds with 21 queries.
