Author Topic: Bl**dy tyre mechanic...  (Read 5223 times)
Johnny English
  • Hungary
  • English antitalent
    • 1995. 2.5 V6 LPG manual
« on: 19 November 2012, 21:09:05 »
...who fitted my summer tyres and fixed the wheel bolts much stronger than allowed so now I can't change them for winter ones... >:( >:( >:( Aarrrrghhh.... >:( I don't want to kill off my bit by torque wrench, of which max is 210Nm and clicked off when trying to untighten the bolts.  >:(  I'm sure it is a method of holding consumers but hey you surely lost me forever...f*ckin d*ck... >:( Even don't mention what would've happend if I'd got a puncture. Ouhhh...okay I'm much better now thx for reading guys  :y  :)
 ;D ;D ;D
C20NE - X25XE
Re: Bl**dy tyre mechanic...
« Reply #1 on: 19 November 2012, 21:20:07 »
Breaker bar and big lump hammer usually "shocks" 'em loose mate.  Agreed tightened by a dickhead.  I always make sure wheel nuts are properly torqued by tyre fitters :y
« Reply #2 on: 19 November 2012, 21:43:13 »
Had this problem when i got this omega , a huge breaker bar and pole with a few portly people on the end got them to crack  :o
« Reply #3 on: 19 November 2012, 22:42:13 »
I have had similar problems in the past, a real pain..... :( :(
« Reply #4 on: 20 November 2012, 10:25:26 »
WIM is the only place I've seen wheels torqued correctly!
Keith ABS
  • Maldon Essex
« Reply #5 on: 20 November 2012, 14:15:11 »
  had this happen years ago on Mk2 Cav. Broke wheel brace, socket t-bar and ratchet after it got two off. stuck on side of road so wouldnt normaly have used the ratchet. got the AA out in the end. he had four foot long torque wrench that clicked as soon as he tried to remove the bolts. he swore and said they were at over 250lb as he hadnt reset the wrench after his last job of lose hub nut.I took the car back to the tyre centre and got then to take the wheels off and refit them with a torque wrench correctly. while I watched. Got reimbursment from them for the broken tools and my time.
Keith B
« Reply #6 on: 20 November 2012, 14:27:04 »
For this, and generally taking my wheels off, I have a 2+metre socket bar on which I have a wheel nut socket on the end.  I have yet to find  any bolt I can't loosen with that. ;)
I advise all to carry one, and not just women :D
Johnny English
  • Hungary
« Reply #7 on: 20 November 2012, 16:06:49 »
  had this happen years ago on Mk2 Cav. Broke wheel brace, socket t-bar and ratchet after it got two off. stuck on side of road so wouldnt normaly have used the ratchet. got the AA out in the end. he had four foot long torque wrench that clicked as soon as he tried to remove the bolts. he swore and said they were at over 250lb as he hadnt reset the wrench after his last job of lose hub nut.I took the car back to the tyre centre and got then to take the wheels off and refit them with a torque wrench correctly. while I watched. Got reimbursment from them for the broken tools and my time.Keith B
Well done Keith !  :y I also have two broken tools an extension bar and a socket  >:( and still not sure whether if alloys and screws are intact... :-\
C20NE - X25XE
« Reply #8 on: 20 November 2012, 16:41:50 »
You're mighty strong for a mere girlie, Lizzie. ;) :-* :-*
« Reply #9 on: 20 November 2012, 17:06:56 »
I am with my long socket pole Opti and all my weight pushing down on it! ;D ;D ;D ;D ;D ;D ;)  Other than that I am weak, but when you have no nice hunky man around you I have to improvise and use brain rather than brawn! :D :D :D :D ;)
« Reply #10 on: 20 November 2012, 20:19:15 »
The weight of an average sized bloke on the end of a metre bar produces about 600nm so I've been told....  :-\
Jukeboxnut
  • West Sussex
    • 2004 2.2 auto CDX estate
« Reply #11 on: 20 November 2012, 22:02:27 »
Me being a seven stone weakling has no chance then!
« Reply #12 on: 20 November 2012, 22:10:28 »
With the correct size lever .. anything is possible ... :)
As a certain gentleman once said ..
"““Give me a lever long enough and a fulcrum on which to place it, and I shall move the world.””"
(for those who don't know .....  Archimedes 280-211 BC)
« Reply #13 on: 20 November 2012, 23:01:07 »
As Entwood quite rightly points out, size matters!  You just need a longer pole!  ;)
78bex
    • 2.2 CD AUTO / FAZER 600
« Reply #14 on: 20 November 2012, 23:13:35 »
You need a Torque multiplier, it looks like a torque wrench but uses planetary gears etc. with hardened sockets.
Comes in various forms, Ring around local garages,  that`s what I did for one of my astra`s omce. The bloke charged me a tenner to loosen of the rear sets both sides. took him all of 10 minutes.
