Wiper stalk/switch
Started by Big_Al, 24 November 2012, 07:29:58
Quotethe one fitted now is 90 494 187
That one is for wiper stalk with intermittent wheel
Quotethe wipers sweep every 1.5 seconds
If no variable stalk fitted, that`s about right
Quote from: Essex Big Al on 26 November 2012, 22:18:09
I am curious as to What is the usual time  delay for the standard non variable  intermittant  sweep before the VW99 mod is made?
As the OP on this thread I asked the question of upgrading because on the first position (intermittant )  the wipers sweep every 1.5 seconds .
I am thinking this is way to fast & must be  incorrect /a fault  :-\
When I recently brought the car there was no intermittant wipers working  at all. That first position of the switch did nothing . Then on speeds 1 & 2 they would not "park" , but just stop wherever you switched off.
Changed the tall yellow relay  & wipers now park fine but intermittant sweep time is as above ( only a 1.5 sec delay )
Does anyone know the part No. for the correct yellow relay. the one fitted now is 90 494 187 .
:-[ :-[can't check the number of the old one that was in the car when I got it  as SWMBO chucked it out in the rubbish   ::) ::) ::)
TIA   Al :y
If memory serves that was what I had before fitting the 99 relay. The old 2.5 had the rheostat which was good, but the "fixed" interval of the 3.2 annoyed me immensely, so the 99 relay is a godsend.
You will get very little delay if you have the timer/relay for the older style stalk with the newer stalk since the old stalk adds resistance to extend the interval.
You can change a resistor in the module to increase the delay, get the correct part which gives you a longer fixed delay, change the stalk of fit a "99" variable relay.
There were plentiful supplies of the "99" relay on Ebay when I bought mine. Must fit it some time  ::) (it's going in the Westfield, which has no intermittent wipe currently).
Big_Al
Quote from: Kevin Wood on 27 November 2012, 09:47:37
Hardly any delay at all Kevin.  I said 1.5 secs , but its even less than that actually.
There still  seems to be plenty of "99's"  on  e bay around the £10 mark . So will order one of those  :y :y
