Author Topic: urgent help - oil sump nut spinning, not coming out  (Read 4825 times)
  • Auckland
    • Mazda MPV
Re: urgent help - oil sump nut spinning, not coming out
« Reply #15 on: 25 November 2012, 14:38:18 »
I fitted a new sump plug in mine at the last oil change because the old one was threatening to behave as described.
I was concerned that the thread in the oil pan might be damaged but it looked to me as though the insert was steel and the plug was a softer alloy (with a visibly damaged thread)
The old plug felt 'wrong' as I was unscrewing it (I needed to use a ratchet to turn it). The new one screwed in sweetly by hand and nipped up nicely at the specified torque :)
Chances are that you won't need a new pan but if you don't know the oil change history of your car it gives you another reason to drop the pan and clean the crud out of the oil strainer......
« Reply #16 on: 25 November 2012, 14:41:19 »
You will need a Heli-coil kit by the looks of it. Be careful if you drive it, keep the revs low & watch your oil pressure. You will more than likely need a new sump plug too.
p.s. Welcome back Lizzie  :y
Thanks! :y :y
« Reply #17 on: 25 November 2012, 14:45:26 »
Hmm, not sure what's happened there, then. I'd certainly never do a sump plug on one of these up "tight" - torque wrench or not... simply 'cos such a low torque is required (due to the rubber O ring not needing much clamping force)
I have had it before when they've been abused in a past life, just let go upon normal doing up / undoing... but whatever the case..
1) if you don't trust it since you've struggled to get it out/in - don't drive it, if you think there's a risk it will dump the oil
2) If you can get it down to me sometime (if it's safe to drive) I'll gladly change the sump FOC if you bring one with you :y
SMD
  • London
    • :( nowt
« Reply #18 on: 25 November 2012, 15:33:01 »
Oil changes have been done quite frequently but all at VX so may have had a troubled past. James, I know you have done enough oil changes to know how tight these should be. I certainly don't think its your fault in any way. Thanks for the offer, but I dont trust driving it a mile down the road, let alone 100m! But if work brings you closer then may be a possibility. A how to would be be useful though.  :y
« Reply #19 on: 25 November 2012, 16:16:59 »
Undo the M6 bolts, lever pan off with screwdriver (held with instant gasket), level sensor is bolted to base of pan and wiring runs up towards rear top of pan (rubber bung). When re-fitting use grey sealant (same as oil cooler)
Andyv6
  • westmidlands
    • Elite 3.0, Vectra b3.0l
« Reply #20 on: 25 November 2012, 17:01:10 »
Just done mine this weekend since I got the omega it has always spun so been doing oil changes by sucking it out the dipstick tube lol, the plug had been overtightened and stripped the thread at the lower end of the plug just got my 3/8 airgun on it spun it like mad and pushed it to one side, soon came out but replaced the lower pan with one I had lying around with the old style sump plug, will see if the thread in the original can be saved or not tomorrow when I get back to work.
SMD
  • London
    • :( nowt
« Reply #21 on: 25 November 2012, 23:34:36 »
Thanks for the guide Rob. Is the level sensor in the way of the sump coming out, ie. does it need removing before dropping the sump?
I will speak to andyc tomorrow about a new pan/plug. The major concern I have with this job is the 5+ litres of oil making a mess. Is it possible to bash the plug with a screwdriver/hammer and punching a hole in it? Dont want to get my drill covered in oil.
« Reply #22 on: 25 November 2012, 23:38:54 »
It's bolted to the inside of the sump, so yes,it needs disconnecting to completely remove the sump ......... it's obvious when you unbolt the lower sump. Be careful of the wiring, it'll be brittle having spent its life in hot oil, mine broke a soldered connection.
« Reply #23 on: 25 November 2012, 23:40:15 »
 Is it possible to bash the plug with a screwdriver/hammer and punching a hole in it?  ......
If you use a big enough hammer & suitable punch/chisel .........  ;) ;)
SMD
  • London
    • :( nowt
« Reply #24 on: 26 November 2012, 17:49:33 »
Bought a new oil pan off andyc today. Quite an expensive oil change  :P. Phoned another VX dealer to see what they would charge for this job - £255 inc. VAT + materials brings it to £360 !
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #25 on: 27 November 2012, 12:20:00 »
Sorry,I'm a bit late reading this but Sealey do a sump bung repair set for about £50 which has slighly oversize taps and over size bungs,you simply choose the tap which is slightly bigger than what you have and re-tap hole and fit the over size bung supplied :y
other rides
SMD
  • London
    • :( nowt
« Reply #26 on: 27 November 2012, 14:59:28 »
I may be wrong but I don't think that will work because if the ally housing has come apart from the steel, retapping in the broken housing will still cause it to spin
henryd
  • west cornwall
« Reply #27 on: 27 November 2012, 15:10:07 »
You may well be correct,not tried them on a vauxhall :-[
other rides
SMD
  • London
    • :( nowt
« Reply #28 on: 27 November 2012, 15:15:34 »
I don't understand why VX didn't have the plug screw straight into the steel?
Page created in 0.028 seconds with 16 queries.
