Author Topic: Tractor has been WIM'd  (Read 3186 times)
« on: 28 April 2008, 19:15:46 »
Today, the tractor went into Wheel-InMotion for a new set of boots, and the full WIM geometry treatment.
We all know that Wheels-InMotion have built up a deserved reputation for doing an excellent job, hence why it was worth the 3hr round trip to Chesham.
The result? Transformation :D.  As regular followers of the tractor saga know, its not shy in being a bit tail happy, which is probably part of the reason the rear tyres lasted 4k (OSR) and 7k (NSR).   The other part of the reason was rear geometry was significantly out.
Now, she travels at speed without constantly fighting a wander and a constant pull :).  And the vibrations have disappeared for the first time since I've had the car (most likely rear wheel balancing).  She also goes around roundabouts with the rear end stubbornly following the front, rather than overtaking the front - not as much fun, but I can carry better speed now.
Now WIM are officially open for business at their new centre, if you need geometry, book it in. Remember to mention Omega Owners for a fixed £85 charge :).
If you think your car just needs tracking, think again - the tractor has obviously had tracking done at some point, but never had the root cause of wear/handling fixed (the rear was out).  4 wheel alignment doesn't ensure your rear is straight, only that rear wheels follow front.  Get a full geometry check done!
Dazzler
  • Haverhill, Suffolk
Re: Tractor has been WIM'd
« Reply #1 on: 28 April 2008, 19:31:47 »
Glad to hear you have it all sorted Jaime, another top job :y
How much more is on your todo list for your Omegas then ::)??
amigov6
« Reply #2 on: 28 April 2008, 19:35:02 »
Since fitting the MV6 wheels i can feel the camber problem so i guess mine needs wimmin' too!!! ::)
« Reply #3 on: 28 April 2008, 19:41:06 »
get down there before it chews the rubber off (it may do this very quickly!)
amigov6
« Reply #4 on: 28 April 2008, 19:56:02 »
Tyre co. knew what it was but did'nt want to do it! :o
« Reply #5 on: 28 April 2008, 20:04:46 »
I wouldn't trust someone who did not truely know what they were doing - its not just a case of making it go green ;)
    • 530D M Sport, 330i Coupe
« Reply #6 on: 28 April 2008, 21:18:41 »
It certainly isn't a case of 'in the green' as Tony explained in detail to me! The back setup on mine was as near as spot onbut the front was all over the shop.
Unfortunately my wishbones are worn (new set in the boot awaiting a return visit to WIM) but Tony set the car up spot on and is going to fit the new wishbones and set it all up again.
On mine the transformation was from barge (that I always assumed was just the way Omega's are) to driven on rails, it really is that dramatic a change!
One thing I would add is that Tony also supplies the tyres at very good prices, along with having a tyre fitting machine that doesn't touch the rim and a balance machine that balances via the bolt holes.  :y
amigov6
« Reply #7 on: 28 April 2008, 21:29:45 »
I've got a knackered wishbone on the offending side & i need front discs & pads SOON. Got some budgeting to do or might not be able to afford the Lakesmeet. Be better off in the next 9 months..loan cleared after 5 yrs but sailing close to the wind 'til then! ::)
    Can a winkered wishbone affect the camber?
platty
  • Cambridge
    • BMW 530d Sport
« Reply #8 on: 28 April 2008, 21:52:43 »
Yes, massively. When I first got my Meega the front wishbones were both shot - this left me with a tyre like this:
http://img.photobucket.com/albums/v241/chrispy_platt/Mega%20Drive/DSC00992.jpg
If you think the wishbone is causing tyre wear - change it asap!!!
edit: Sorry - pic was bigger than expected
« Last Edit: 28 April 2008, 22:15:55 by platty »
amigov6
« Reply #9 on: 28 April 2008, 22:14:18 »
Yeah, got serious neg on the front. So i really need both wishbones, front discs & pads before i knacker the tyres. Luckily i cover low mileages & can afford to get it sorted but no meets for me this year.
   That's ok i needed a new tent anyway so saved a few quid there! :(
« Reply #10 on: 28 April 2008, 22:21:33 »
can't you get a lift with someone to the meets?
amigov6
« Reply #11 on: 28 April 2008, 22:53:44 »
Could'nt go without the car, she'd never forgive me! Rather get it all fixed up with new parts fighting fit for next year. :y
bob.dent
  • Hertfordshire
  • Drives better than an Omega
    • Mondeo 2.0TDCI Estate
« Reply #12 on: 29 April 2008, 09:48:48 »
Good to hear Jaime. :y I'm booked in on Friday this week for geometry and new front boots. It's a bit of a trek for me now that he's moved from Hemel Hempstead but worth it. :)
« Reply #13 on: 29 April 2008, 09:51:50 »
Its only 6 or 7 miles the other side of Hemel - Boxmoor, Bovingdon, Chesham ;)
bob.dent
  • Hertfordshire
« Reply #14 on: 29 April 2008, 09:54:41 »
Great, I thought it was quite a bit further than that but then I haven't checked on the map yet. ::) Probably take me about an hour or so each way then so not so bad. :y
Page created in 0.037 seconds with 20 queries.
