Pages: 1 2 3 4 [5] 6 7   Go Down
Author Topic: Heating and conditioning stoppes in omega 2.2l 2001  (Read 18744 times)
gibby
  • braintree
Re: Heating and conditioning stoppes in omega 2.2l 2001
« Reply #60 on: 11 December 2012, 11:07:33 »
If resistor is donald, fans will run on unless fuse #33 is pulled
Not always. Sometimes the failure mode is where it will not provide any power to the fan motor.  In fact, IME, this seems to be the most common failure mode. Only seen the constant running if its been soaked by the scuttle drain.
gibby
As it seems the fan is non functional (I assume you have tried manually turning the fan right up ;D), I would suggest removing the glovebox, disconnect (and insulate!) the wires from speed controller, and apply a 12v fused feed to the fan directly, to see if it spins. If it does, I'd be suspicious of the speed controller (hedgehog).
Also, has your scuttle drain blocked, as that can kill the speed controllers, as they don't like water.
Hi hon Theboy, so what is the possible cure to the prob which you've tables? Thanks
gibby
  • braintree
« Reply #61 on: 11 December 2012, 12:38:27 »
As to no hot air either, check first that the pipes going to the bulkhead are hot. There could be a vac problem causing no heat. Easy test if its a vac problem is pull the vac hose off the top of the HBV.
Have you done this?
Hi Hon RobG, yes the bottom pipe to bulhead is cold and the top pipe is very warm. Thanks
« Reply #62 on: 11 December 2012, 13:40:03 »
Have you done this?
Blocked matrix, needs a thorough flushing   http://www.omegaowners.com/forum/index.php?topic=90620.0
« Last Edit: 11 December 2012, 13:43:10 by RobG »
« Reply #63 on: 11 December 2012, 14:11:27 »
Have you done this?
Hi RobG Hon, yes the bottom pipe to bulhead is cold and the top pipe is very warm. Thanks
Fixed that for you Gibby! ;) ;D
« Reply #64 on: 11 December 2012, 14:14:47 »
Have you done this?
Far cough you :P :P ;D
« Reply #65 on: 11 December 2012, 15:17:12 »
Gibby.When flushing the matrix you may find it easier to disconnect the other end of the pies,rather than the so called quick release connectors at the bulkhead.The bulkhead connectors are often reluctant to release quickly,slowly or any other way.
But as Rob says,a sure sign of a blocked matrix.Needs flushing through,then refill with new coolant. :y
gibby
  • braintree
« Reply #66 on: 11 December 2012, 15:33:47 »
Have you done this?
Hi Sir, thanks that sounds good because once the prob is known you konw what needs to be done. I will study the link you've posted and try to work on it, and report the out come. Once again thanks very much for you help, I really appreciate that.
gibby
  • braintree
« Reply #67 on: 11 December 2012, 16:11:47 »
Hello Sir, nice to hear from you, thanks for the advice, I'll try the way you've instructed and see where we're going to land with this prob, thanks very much.
gibby
  • braintree
« Reply #68 on: 11 December 2012, 16:19:00 »
Have you done this?
Well, thus sounds good :y
gibby
  • braintree
« Reply #69 on: 11 December 2012, 16:44:38 »
Have you done this?
Hi sir, just a quick one, how long should this prosess last? Its not specified in the link you posted. Thanks
« Reply #70 on: 11 December 2012, 16:56:31 »
5-10 mins forward flush and the same when you reverse flush should be ample :y
gibby
  • braintree
« Reply #71 on: 11 December 2012, 17:06:27 »
Thanks sir, during this time should the engine be running or not? Sorry for bothering you.
« Reply #72 on: 11 December 2012, 17:07:49 »
No. You`re not bothering anyone Gibby, everyone here are willing to assist/advise :)
gibby
  • braintree
« Reply #73 on: 11 December 2012, 17:31:10 »
You're a good man hon RobG, may the dear Lord bless you sir. Thanks
« Reply #74 on: 11 December 2012, 17:50:01 »
Im really sorry I cant come and physically help this time Gibby,but circumstances prevent it.I will send you a PM. :y
Pages: 1 2 3 4 [5] 6 7   Go Up
Page created in 0.029 seconds with 20 queries.
