Author Topic: When "Should" the Powersounder sound for real ?  (Read 4815 times)
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
« on: 01 December 2012, 14:27:21 »
Hello
I've just replaced the powersounder and alarm horn on my car as the powersounder batteries were dying and the circular horn on the last one never worked .
So when i plugged in the powersounder it started going off and kept going off dispite locking and unlocking the car several times .
It did stop going off eventually however and i thought thats fine .
So now if i lock the car using the fob then open with the key i now get a honk from the HORN every second or so until i press the fob again ... i assume this is how it should be ?
So when should the powersounder go off though .... it used to go off at silly o'clock for no reason ... how do i test it to see if its working properly though ? Do i have to disconnect the battery for it to go off ?
Dont really want to do that just now though as im at work  ;)
Re: When "Should" the Powersounder sound for real ?
« Reply #1 on: 01 December 2012, 16:27:34 »
Generally if you disconnect the batt
Proz
« Reply #2 on: 01 December 2012, 16:44:05 »
So it sounds like its all working as it should then ?
Should never hear the powersounder unless someone tries to disconnect the battery ?
« Reply #3 on: 02 December 2012, 06:43:54 »
It goes off with the alarm. So whenever the alarm trips.
Leave a window open when locked, without pressing the internal sensors button.
Jacking the car up while locked.
Disconnecting the battery
...are the ones that catch me out. ;D
Proz
« Reply #4 on: 02 December 2012, 08:02:15 »
Mmmm well i went to start the car this morning and let it run to warm up when the alarm power sounder goes off as soon as i turned the key .
Still went off when key removed and locked unlocked etc .
Eventually stopped .
Maybe the powersounder was flat and still needs charged up ??
« Reply #5 on: 02 December 2012, 09:45:59 »
Does your alarm horn work?
« Reply #6 on: 02 December 2012, 11:45:43 »
nope. Woowoop, but no bleetbleet.
Proz, I'd remove your sounder. And check alarm activations with tech 2, to confirm loopy ps.
« Reply #7 on: 02 December 2012, 13:53:35 »
Thats probably why your PS goes off instead, as it detects fubar horn
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #8 on: 07 December 2012, 22:10:43 »
Bit late now but the recommended thing to do with a power sounder is remove it from the car and dont replace the dam fire hazzards,lots of threads about them,ive had 1 car go up in flames due to a dodgey sounder.
  Death to the sounder :)
Hoof'land storeman.
