A Jaguar and Another VX joins the JV6 household!
Started by JamesV6CDX, 05 December 2012, 10:15:08
Pretty much all the rolling road folks do it post CAT - from what I understand you just need to 'adjust' the figure you're looking at as it looks constantly slightly leaner than it really is.. oh and slower to respond I guess.
I guess it's easy enough to swap it in place of a factory O2 sensor; given you're already messing with the wiring doing the LPG kit, just find the relevant wires into the ECU and splice it in with a suitable connector.
Gaffers
Remember on the AJ16 there is 1 cat pre lambda and another further down the exhaust, will that not affect taking the reading at the tailpipe?
The second lambda won't make any odds, but measuring after the cat won't give you a true picture of what's going on.
That said, the cat will not be doing a great deal at full chat. Most of the exhaust gas will go straight through, so from a point of view of being able to compare the situation on petrol and LPG and adjust accordingly, it might be good enough. :-\
Trouble is that those transient lean periods wont show up post cat as it effectively 'smooths' the response.
