Author Topic: Boiler Spark Plug?  (Read 15243 times)
Re: Boiler Spark Plug?
« Reply #30 on: 06 December 2012, 20:49:31 »
Tunnie you say your on the 5th floor.  Where does your pressure relief valve vent to? Does it go straight through the wall?  Can you see it out of a window?  If you can, keep an eye on it to see if it's dripping...  ;)  Might be that the spring has got weak in the pressure relief valve...  :-\
« Reply #31 on: 06 December 2012, 21:29:59 »
Sounds familiar. Any popping or banging from the boiler, any bubbling in the pipes?
« Reply #32 on: 07 December 2012, 08:46:05 »
I sometimes read these threads and do wonder if im doing the right thing by planning on swapping out my 30yo boiler for a condensing combi.  :-\
When I bought my flat, it was my first experience of a combi boiler. I really do like way it works, hot water on demand, no need to turn on water heater or spark it up 30 mins before you want water. Or having it on a timer, then getting up earlier one day and getting no water, its just always there.
Keep a close eye on the pressure over the coming weeks, in case there is a small, as yet undetected, leak, or if the expansion chamber is fubar...  ...and resolve any issues before it becomes a bigger problem. Esp if it means Mrs Tunnie has a cold shower - I can imagine her suffering a sense of humour failure under such conditions in this weather ;D
Yup, going to keep a close eye on it  :y
Got some points though for fixing it  :D
I was quoted similar call out prices as yourself tunnie
They were insane, strongly considering a course!
Yes I can see it out of the window, will keep an eye on it, did'nt think of that  :y
Not really, its fairly silent when its running  :-\
« Reply #33 on: 07 December 2012, 09:25:04 »
I've just been through all this with mine. Old boiler kettling. Fit new boiler, still kettling. Fit press pack(pressure vessel) in place of the water tank and stop cock. Gauge dropping, pressure lost, boiler makes a racket as there's no water in it then cuts out. No heat or water.
Reason for pressure loss, leaking heating pipes under the concrete floor. These had been leaking since the house was built. The pressure vessel just exaggerated the problem, and helped us find the leak effectively.
The 1.5 bar comes from mains water pressure on our system, and is topped up manually by allowing water pressure back in via a tap.
I have learned that a leak on hot water pipes is quite hard to find, as the hot pipes evaporate the leak away, and passing pumped water can pull air in.
« Reply #34 on: 07 December 2012, 09:26:54 »
Should add, other possible is failed valve from pressure vessel to over flow. Keep an eye on the over flow from the boiler.
« Reply #35 on: 07 December 2012, 09:28:30 »
How long did it take to loose pressure? I'm going to keep a close eye on it  :y
« Reply #36 on: 07 December 2012, 09:34:44 »
At its worsed, it was loosing all it's 1.5 bar in 24hours. We have fixed the worsed leak, but it's still loosing 0.3bar over 48hours.
Having said that, ours needs topping up 3 or 4 times a year anyway as part of normal use. I don't know if yours will top up automatically with water, or you have to do it manually and that's the only problem your seeing...?
« Reply #37 on: 07 December 2012, 09:38:16 »
I don't think it does, I just opened valve manually to let in water. Its been at least 6 months since it was last done, so hoping its just that.
« Reply #38 on: 07 December 2012, 09:39:19 »
sounds likely :y
« Reply #39 on: 07 December 2012, 12:29:36 »
Water regs dont allow for auto fill as that would require a permanent mains cold water connection.  :y
« Reply #40 on: 07 December 2012, 14:06:27 »
I think I'd rather eat my testicles than have a combi.
I have only ever seen one usablable combi for a 4 bedroom house, and that my bro's. Stands floor to ceiling, and is massive. But does allow 2 taps on at the same time.
« Reply #41 on: 07 December 2012, 14:09:20 »
I'd agree for a house, but a flat its fine  :)  :y
« Reply #42 on: 07 December 2012, 14:15:13 »
Yeah, agreed, combi's have a place. Well suited to single occupancy accomodation...  ...as long as you remember not to get in shower when washing machine is on ;D
« Reply #43 on: 07 December 2012, 18:22:39 »
Gotta love a noisy old boiler!!!  :)
« Reply #44 on: 07 December 2012, 19:09:34 »
it tells you when it's working. :y
Pages: 1 2 [3] 4  All   Go Up
