Author Topic: Alarm false triggers - buzzing in car (relay?) - internal lights flashing.  (Read 2117 times)
driag
  • Manchester UK
    • Omega 2.2CDX
Dear All,
I'm on my third Omega (2.2CDX) having had great service from them over the years (until now!).
Over the last few months the following has happened:
False alarms - car battery replaced by local garage.
Problem not solved -  the the powersounder unit was then removed (by local garage) - something about possible faulty backup alarm battery - problem still not solved.
I currently take the negative battery connector off overnight to stop being woken by the alarm!
Today while driving a loud buzzing could be heard under the steering wheel (relay?) and the internal courtesy light flashes continuously until the main light switch is turned off.
I read a previous message on the old site which tended to say its the actual main light switch that may be the problem.
Any help suggestions much appreciated.
Alarm going off - possibly micro switch under bonnet not adjusted correctly - try disconnecting it (pull off plug) to confirm.
Light issue - I would suspect ligh switch - swap with a known good one (from OOF breaker) - 5 minute job to swap ;)
driag
  • Manchester UK
    • Omega 2.2CDX
Thanks for such a prompt reply dbug.
Do you know of a good website or breaker in the Manchester area that may have the lightswitch?
Regards,
draig.
Regards,
draig.
I haven't looked, but was told that one of the yards at Pimhole (Bury jct of the M66) has an Omega  :-\
Look in the parts for sale section - sure one of the breakers on the forum can help with a light switch :y
driag
  • Manchester UK
    • Omega 2.2CDX
Contacted the local Vauxhall dealer today, the main light switch was £175 !
Ordered a secondhand one from one of the omega breakers for £10 + p&p !
Will re-post if I fix the problem when the switch arrives.
Regards and seasons greeting.
£175 - was the parts guy weraing a mask and carrying a gun?
Glad you got it sorted sensibly :y
« Last Edit: 11 December 2012, 20:31:26 by dbug »
