Audi question
Started by BazaJT, 17 December 2012, 17:22:32
BazaJT
One of my workmates has a "Y" reg.Audi 2.5 diesel A4.The battery has started to go flat,so she's asked a garage to check it out for her,the garage told her it has to go to a dealership as disconnecting the battery to test for current draw means she'll not only lose the radio coding[not a problem as she has the code]but also information on steering angles and other information so it would need putting on a machine to reset these values.Has anyone heard of this kind of thing or are they fobbing her off because they don't want to know?
henryd
Most systems do a self test on start up so can't see a problem to be honest,I don't think they want the job :-\
other rides
doz
There is some truth in what they are saying but it's no big deal. You can just connect it back up. If it does decide to flag a fault it's easily reset using something like VCDS. As for steering angle. Just turn it lock to lock.
It's a pretty cr@p design if the systems can't cope with a battery change! Then again, it's an Audi. :-X
BazaJT
As expected it was aload of baloney,they can't have wanted the job.She took it to another place this morning,quick electrical check[about twenty minutes of testing etc.]and problem found.Turns out it was the alarm siren drawing more current than it should,disconnected and removed a la Omega power sounder  job sorted!
tidla
The steering light may come on, but once mobile and a couple of turns it usually goes out.
Quote from: Kevin Wood on 18 December 2012, 09:39:56
Some of the Mercs are worse!
ngrainqey
Quote from: Marks DTM Calib on 18 December 2012, 18:06:03
V8!!!!
