Author Topic: Spare key  (Read 6065 times)
dazzle72
  • nottinghamshire
    • Omega 2.2 CDX Estate
Spare key
« on: 19 December 2012, 20:11:32 »
We need another key for our car, as it only came with one. If we get another 2 button remote one, is it a dealer only job to get it programmed in?
Re: Spare key
« Reply #1 on: 19 December 2012, 21:43:50 »
Given your location, get the programming done by Marks DTM Calib in Nottingham. Bloody nice and helpful chap, but don't tell him I said that.
You need:
Blank 105 key with transponder (about a tenner from ebay)
The correct fob (looking identical isn't enough, has to be right manufacturer and model)
Carpass (this has the security PIN on it)
Programming (Marks DTM)
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Spare key
« Reply #2 on: 20 December 2012, 00:12:35 »
The local locksmith we use at work quoted me £65 to supply and code a 2 button remote for my facelift estate. This was last week.
They keep them in stock and will do it while you wait. You do need the car pass though.
dazzle72
  • nottinghamshire
Re: Spare key
« Reply #3 on: 20 December 2012, 16:52:37 »
And I guess the car pass is the security thing mentioned on a post about fobs that you have to get from Vauxhall? The battery in the remote we have seems to be getting weak. Can I just open it up and replace, or will it lose its memory and need reprogramming? Thanks for the help as always
Re: Spare key
« Reply #4 on: 20 December 2012, 17:27:06 »
... Can I just open it up and replace
Yes  :y
No
No ..... it might just need synchronising with the car ie ignition on, press lock. The car will lock & then unlock ...... that's it!  ;)
Toledodude1973
  • IPSWICH U.K.
  • 2002 2.6 elite,1973 ,Gas van,1974 victor fe
    • 2.6 OMEGA ELITE 2002
Re: Spare key
« Reply #5 on: 20 December 2012, 18:31:05 »
Just bought spare key from vauxhalls ,had to be programmed cost me £120 for my daughters Corsa they told me it was my only choice! Certainly hurt the wallet also took hour and a half to do
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
Re: Spare key
« Reply #6 on: 20 December 2012, 18:33:24 »
If it makes you feel any better, it cost me £190 for another key for SWMBO's Smart!  :'(
dazzle72
  • nottinghamshire
Re: Spare key
« Reply #7 on: 20 December 2012, 18:40:16 »
Tell me about it. Used to work in parts dept at a Ford and Rover dealer. £100 ish for most Ford's with one key. Double that for a Rover 75!!!!!
Re: Spare key
« Reply #8 on: 20 December 2012, 19:36:05 »
OOFers near our Tech2 peeps should get change from £50 for a brand spankers complete key (pattern blade, pattern transponder, genuine fob) fully programmed. Assuming they have their carpass.
Carpasses are £15-£50, depending on how crap your dealer is.
Re: Spare key
« Reply #9 on: 20 December 2012, 19:50:04 »
Plenty of change  :y
dazzle72
  • nottinghamshire
Re: Spare key
« Reply #10 on: 20 December 2012, 20:03:55 »
£50 complete sounds like a bargain to me. Might have to have a ride in the new year, once its running right and serviced, etc
Re: Spare key
« Reply #11 on: 20 December 2012, 21:22:32 »
If you can't get it done through an OOFer due to distance ... then a mate of mine used these folks (non-Omega) but rates them extremely highly ...
http://www.carkeyworld.co.uk
He actually snapped his only key, but phoned them and with the number off the key, and the data off the equivalent of the car pass, and a few security checks ... a new key arrived with 48 hours .. and worked perfectly ....
as said .. he rates them .. but I've (touches wood) not had any personal dealings ....
HTH  :)
Re: Spare key
« Reply #12 on: 20 December 2012, 21:27:56 »
I may need to place an order in the comming weeks   :y
Can you remember 2.2s code  ::)
dazzle72
  • nottinghamshire
Re: Spare key
« Reply #13 on: 20 December 2012, 23:17:02 »
Round here I'm limited to dealer really, so I'd rather put a few quid in someones pocket off here than the dealer. And its a ride out
Re: Spare key
« Reply #14 on: 20 December 2012, 23:32:16 »
A I've pointed out a few times, MarksDTM is near you  ;)
He has tech2 & unlike dealers, knows how it works  :y
Page created in 0.028 seconds with 20 queries.
