Author Topic: Nav disc popped out  (Read 2806 times)
Nav disc popped out
« on: 22 December 2012, 23:43:59 »
Not using Nav. Radio only, driving along. Disc pops out over a speed bump.
Whatzatden? Surely it's not reading the disc when not in use?
It went back in on it's own.  ???
Re: Nav disc popped out
« Reply #1 on: 22 December 2012, 23:55:12 »
Possibly the start of the laser playing up ??? Mine spits the disc out with monotonous regularity, then sucks it back in, until the radio system has got really warm ... about 30-40 minutes usually before it settles down.
I think the reason is that when I got the car it had a pirate, copied disc in .. replaced with a genuine but my guess is the damage is done.
I keep thinking about buying a replacement laser unit of the bay .. a german store has them ... but I'm not sure my electronic skills are good enough to do the job.
Perhaps someone who "does" electronics will be attending Guffers meet with nothing else to do ... if so I'll buy one and pay beer money for the job to be done ... :)
Mind you .. I hope to change the radiator at the same meet .... if I can make it once the date is fixed :)
« Reply #2 on: 23 December 2012, 00:22:14 »
Yes the jobs are building up aren't they.
The other car is the same as yours. Good while to warm up.
Is it worth removing the disc if not using the Nav I wonder...? Inconvenient but...
« Reply #3 on: 23 December 2012, 09:08:51 »
Yeah, the tell-tale signs of the laser dying. Might be worth cleaning the disk if its got fingerprints/marks on it.
« Reply #4 on: 23 December 2012, 10:44:36 »
Is it worth removing the disc when not in use? Would that save the laser a bit?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #5 on: 23 December 2012, 11:43:58 »
Not really - when powered up, it will spin the disc and sense the disc is there but won`t be reading it all the time - It may periodically check for the disc, but not really enough to cause any wear.
Radio & Decoding Technician
www.dndservices.co.uk
« Reply #6 on: 23 December 2012, 18:34:17 »
Dunno, on these, they do seem to go to the disk quite a lot, even when not in use.  Hence, it can pop out 30mins or so after starting. But more normal to do so within first 5mins or so.
    • 530D M Sport, 330i Coupe
« Reply #7 on: 23 December 2012, 19:20:54 »
Device is always receiving updated positioning from the antenna so will be constantly updating the map position regardless of user input / not using NAV functionality.
Weds
  • Chatham, Kent
  • My other hobby
    • Mercedes E class 350 CDi
« Reply #8 on: 23 December 2012, 21:26:39 »
mine does this as well...
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #9 on: 24 December 2012, 13:00:49 »
What if you put a Music CD in there for a week, I know its not the same as a Nav Disk but will give an idea with whats going on with temperature, cold to warm up etc.
Failing that check Nav Disc for Curry Doggy Bag stains.   ;)
« Reply #10 on: 28 December 2012, 09:02:04 »
Yep, CD70's do the same
