Author Topic: Any tin bashers/machinists in the house?  (Read 1173 times)
« on: 23 December 2012, 20:00:56 »
I need some "washers", which I can't seem to find for love nor money...
32mm outside diameter (there is some flexibility in this)
24mm inside diameter
4.9mm thick
It needs to be rustproof, so was thinking stainless? I understand this is a pig to machine, so other options??
Re: Any tin bashers/machinists in the house?
« Reply #1 on: 23 December 2012, 20:13:39 »
4.9mm thick
I'm not back in work till the 3rd Jan,  they should not be problem, as long as they've not moved the lathe again  ???.
Stainless is a little more difficult than mild steel because it's a bit softer ....... but by no means 'a pig'.
« Last Edit: 23 December 2012, 20:16:23 by Andy B »
Taxi_Driver
« Reply #2 on: 23 December 2012, 20:24:29 »
4.9mm thick
Should you require them sooner than that, Im sure Mr DTM could knock some up for you, inbetween his chrimbo dinner and chrimbo pudding  ;D ;D
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #3 on: 23 December 2012, 20:40:47 »
4.9mm thick
I'm back at work on the 2nd Jan but I've got some galvanised pipe in my garage that can either be parted off or hack-sawed to the required thickness if you're in a hurry. Slight difference in diameter though.
Pipe is OD 33mm & ID 25mm, thickness would be your choice or however good you are at sawing pipe straight.
Any help to you.  :)
    • 530D M Sport, 330i Coupe
« Reply #4 on: 23 December 2012, 20:44:22 »
4.9mm thick
I make it 4.5mm thick x 4 (one each side = 9mm)
Page created in 0.037 seconds with 20 queries.
