Pages: 1 2 3 [4] 5  All   Go Down
Author Topic: Do people use camshaft gauge to install timing (camshaft) belt?  (Read 10538 times)
Re: Do people use camshaft gauge to install timing (camshaft) belt?
« Reply #45 on: 28 December 2012, 18:10:38 »
3.6 is a push rod lump, totally different beast I believe  :y
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #46 on: 28 December 2012, 18:22:17 »
The whole timing marks vs the timing tool is intersting to me.
Before I started college having done one cambelt job on my play car, I assumed that every engine irrespective of type (SOHC, DOHC) would have to have a timing tool kit. However on most of the cars we do timing belt jobs on (all 4 pots) we rely on the timing marks and it always seems very wrong to me not to use a timing tool or at least something of similar ilk to the )( tool the V6 requires. Perhaps it's a cost thing... obviously would be major expense to have different tools for lots of different engines..... I think I'll enquire when I'm back.
Ps, to the OP definitely take the advice and get the proper tool. I was just talking about the jobs we do on old wrecks.  :y
RIP Paul Lovejoy
« Reply #47 on: 28 December 2012, 18:36:09 »
Most engines, esp SOHC and DHOC, its not infineately adjustable. Its either bang on, or a tooth or more out, and obvious.
GM 54 degree V6 is infinately adjustable, so you can never tell how far out it is.
Webby the Bear
  • Northampton
« Reply #48 on: 28 December 2012, 18:44:16 »
infinately adjustable by the idlers, for example? yeah i see what you mean about it being bang on or obviously out... but still if i was in a dealership i'd want to have a tool.
i should've also mentioned that, mainly on the french shite boxes weirdly, the camshaft has a built in timing tool e.g. a hole in the sprocket lines up with a hole in the head and you know its bang on when you can get a certain sized allen key in.
interesting!
RIP Paul Lovejoy
« Reply #49 on: 28 December 2012, 18:45:07 »
The 1700 SOHC diseasal lump in my Astra used just a taper to hold the cam pulley to the cam ie no woodruff key (I believe other manufacturers do something similar  :-\), so that was infinitely adjustable too. That needed a specific tool to set the pulley to the cam ....... I just didn't separate them.  ;)
« Reply #50 on: 28 December 2012, 21:49:12 »
Indeed, surprisingly common. Omega TD has a similar setup, and thats how you adjust cam timing. Their is, obviously, a special timing tool for that.
« Reply #51 on: 28 December 2012, 21:50:30 »
interesting!
Most 16v twin cam setups have a wedge to lock the cams together, similar to the V6 red or green ones. Nothing, normally, to lock the crank, or a tool to measure the timing.
car5car
  • Florida USA
    • 01 Cadillac Catera
« Reply #52 on: 28 December 2012, 21:57:25 »
Manufacturers are just trying to make auto mechanic's life hard. This is what they are thinking about every day and night. They are very creative.:)
"Let us make mechanics buy $300 special tool kit"
"Let us save $3 on transmission dipstick"
I could check engine codes by turning key 3 times on my 97 Jeep Cherokee. The only difference between 97 and 98 is that you cannot get codes w/o code reader on 98. :'(
01 CADILLAC CATERA 3.0 engine (Omega)
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
« Reply #53 on: 28 December 2012, 22:26:45 »
I looked at it when I fitted a new cambelt kit as part of my blown head gasket engine rebuild, that the cost of the locking kit was less than I was saving in doing it myself.
From the post above, if by doing it accurately you get a 3mpg improvement say from an average of 21mpg to 24mpg over 40,000 miles that is 237 gallons less fuel used. That makes not using the kit rather expensive! At over £6 for a gallon of fuel here that is £1422 or about $2133.
My cam locking kit cost just over £60 or $90!
Save £60 and spend over the next 4 years an extra £1362! Doesn't make sense to me not to.  ::) :o :o :o :o
car5car
  • Florida USA
« Reply #54 on: 28 December 2012, 23:58:11 »
If anybody wants to buy american timing tool kit, here is where: ;D :) ::)
http://www.autotoolworld.com/product.asp?itemid=149219&gclid=CIyPvMymvrQCFQWonQodGQ4AHg
« Reply #55 on: 29 December 2012, 00:06:32 »
$940 - you've got to be joking :o  You can buy new in UK for ~ £150 - got mine 2nd hand, hardly used for ~£50. ;)
« Reply #56 on: 29 December 2012, 00:09:04 »
Christ!  :o :o :o You can buy mine for a bargain $500 ........ half retail price!  ;D ;D ;D
http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2045573.m570.l2736&_nkw=vauxhall+v6+cam+lock+kit This brand new.  ;) ;)
« Reply #57 on: 29 December 2012, 00:35:01 »
I think quite the opposite tbh.
The omega drive by wire engines have the pedal trick. Something gm introduced as a get by in the absence of tech2. Not all country's are as we'll off to afford dealer prices and back up.
I consider the timing marks on the rear cam belt cover to be the mechanics equivalent of the pedal trick, a sort of get by, again, in the absence of the proper factory kit.
Once you've used a locking kit, and indeed tech2, you'll realise the advantages of both.
They save a great deal of time, and accuracy in set up and use generally.
You pays your money...
« Reply #58 on: 29 December 2012, 01:05:49 »
See recommended suppliers
car5car
  • Florida USA
« Reply #59 on: 29 December 2012, 02:04:53 »
Sorry, I don't British pounds, only dollars. ;D
Well, if I buy yours for $500, I can resell it here for $800... :y ::)
I used special rope to hold sprockets and I can sell it cheap! Looks like new!
I will include dirty rag, which I used to hold timing belt on crank sprocket for free! ;D
Wait a minute, did I remove it before installing front cover or not? ;D
« Last Edit: 29 December 2012, 02:08:09 by car5car »
Pages: 1 2 3 [4] 5  All   Go Up
Page created in 0.281 seconds with 16 queries.
