Author Topic: Fitting a Nokia CK7-W Bluetooth Kit  (Read 9936 times)
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
« on: 28 December 2012, 18:33:19 »
Hi all,
My dad wants me to fit the above kit into his 2000 cdx. It has the ccr2006 radio fitted.
Having looked up the wiring instructions for the kit, I need to know which wires are which on the back of the radio.
Nokia Wires:                      Omega Wires:
Red                12v Battery Feed
Blue                                     Ignition Feed
Yellow                                Mute On Radio
Black                                  Vehicle Ground
Pictures/diagram or very very simple guide ( ::)), would be very much appreciated!!
TIA :)
AKA - Mr Bracket
Re: Fitting a Nokia CK7-W Bluetooth Kit
« Reply #1 on: 28 December 2012, 18:37:40 »
Don't fit the nokia speaker, its shite. Pipe the audio through HU.
If car is prewired, just buy the correct autoleads kit.
blackviper90210
« Reply #2 on: 28 December 2012, 18:43:45 »
That's not a bad idea, never thought of that, although the wires on the Nokia kit have been "customised" at some point.
There are 4 wires at the plug end on the Nokia unit, amongst the taped up wire, another 4 wires have been added?? Then at the end, it's back to 4??
All good fun.   Will look up the auto leads and see which ones I need, cheers for that TB :y
AKA - Mr Bracket
  • Auckland
    • Mazda MPV
« Reply #3 on: 28 December 2012, 20:46:03 »
Autoleads 06-109b
http://www.armourauto.com/sites/armourauto.com/files/AUTOLEADS_CATALOGUE_FullDocument%28Low%29.pdf
Ignore the reference to SAAB. I used the exact same lead to connect a Nokia CK7-W to my ccr2006 using the connector taped up behind the glove box.
I even posted up a picture somewhere...............
« Last Edit: 28 December 2012, 20:51:22 by Andy H »
« Reply #4 on: 28 December 2012, 21:47:18 »
With autoleads, none of the nokia provided wiring is used, bar the wiring to the CK-7W button. The autoleads plugs straight into the 4 pin socket, and the audio jack plug.
However, you do need to ensure the prewiring is present in the car (aerial on the saloon roof is a tell tale).
I would recommend running and using the Nokia mic, rather than any mic Vauxhall may have fitted, due to poor pickup of the Vauxhall ones.
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #5 on: 28 December 2012, 21:48:56 »
Autoleads 06-109b
Yep, still using this on mine, with behind glovebox connector and NCDC2013. Pairs with iPhone as good as gold.  :y Mine doesn't mute radio though so I use it in basic mode which means I didn't have to remove the radio.  :)
TB did offer to have a look to try and find out why mute didnt work (traffic master issue maybe) but I never got around to it.
« Reply #6 on: 28 December 2012, 21:53:38 »
Autoleads 06-109b
Pop it over any time :)
blackviper90210
« Reply #7 on: 28 December 2012, 22:10:00 »
Even better!!
Thanks for the info TB :y
Surf the net time to find one now ;D ;D ;D
AKA - Mr Bracket
YZ250
« Reply #8 on: 28 December 2012, 22:10:47 »
Autoleads 06-109b
Cheers. I'll catch up with you in the New Year anyway.  :y
Blackviper, I'm using Nokia kit with Nokia speaker and mic and Auto-leads kit. If the pre-wired connector is taped up behind glovebox it's a doddle to fit this way and does the job but is not as posh as connecting to the radio.  :y
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Radio & Decoding Technician
www.dndservices.co.uk
blackviper90210
« Reply #10 on: 01 January 2013, 18:26:05 »
Autoleads 06-109b
Cheers for that Andy!!
Found that plug, isolated the 4 wires I needed and connected them to the Nokia kit. Worked 1st time!!
No need to buy any leads in the end  ;D
Thank you all for your help and advice, much appreciated  :y
AKA - Mr Bracket
« Reply #11 on: 01 January 2013, 18:49:40 »
Well, if just 4 wires connected, you've bodged it  :'(
What did I say about how utter shite those Nokia speakers are? Now go and do it properly, and wire up the audio to the HU.
//TB goes off to find a brick wall to adjust his forehead...
    • 530D M Sport, 330i Coupe
« Reply #12 on: 01 January 2013, 20:50:50 »
PMSL  ;D
steve6367
« Reply #13 on: 17 March 2013, 10:10:05 »
I am just undertaking this job and wonder if the pin out for the pre wire plug is known? I want to use the prewiring and trying to save time with multimeter / tracing wires.
Thanks
Steve
« Reply #14 on: 17 March 2013, 10:23:43 »
Far easier and tidier to just buy an Autoleads 06-109B than butcher the wiring.
I've modified the Autoleads looms to fit different car kits in the past (ditched Nokia kits and now use Bury kits so you can change the cradle easily) which is a more sensible option in my opinion.
Page created in 0.026 seconds with 20 queries.
