Author Topic: Wtd: Track rod end rubber boots  (Read 6032 times)
« on: 29 December 2012, 09:36:29 »
Mine have started to perish, but looks like TRE itself is OK, so was going to just replace the boots.  Need the clip with them.
unlucky alf
  • worksop, notts
Re: Wtd: Track rod end rubber boots
« Reply #1 on: 29 December 2012, 09:50:46 »
You'll find that most good motor factors are doing the dust covers on their own now TB, I had to do mine for the last MOT. :y
unlucky alf
  • worksop, notts
« Reply #2 on: 29 December 2012, 09:55:09 »
Just found loads of people selling them on the Bay as well. :y
« Reply #3 on: 29 December 2012, 11:16:24 »
Do they vary in size?
Cheers Unlucky Alf :y
« Reply #5 on: 29 December 2012, 12:45:22 »
Yep
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #6 on: 29 December 2012, 12:47:34 »
Normally loads of sizes available. Inside hole Dia, 10mm top 30mm lower fits nicely from memory.
Good luck getting the lower spring back on, I ended up using 2 small cable ties together, you know the type BT Outlet Socket type.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #7 on: 29 December 2012, 13:36:09 »
Balljointboots.co.uk
« Reply #8 on: 29 December 2012, 13:52:50 »
Same here.Trying to fit those wire clip things is like pushing custard uphill with a fork. :y ;D
unlucky alf
  • worksop, notts
« Reply #9 on: 29 December 2012, 14:05:33 »
The ones I got came with rubber 'O' rings instead of the wire type, But they are fun to fit when youve got greasy fingers >:(
« Reply #10 on: 29 December 2012, 18:50:40 »
Brilliant, just the info I needed :y
« Reply #11 on: 29 December 2012, 18:58:27 »
Did you save the boots off the wishbone ball joints? Might be the same.
« Reply #12 on: 29 December 2012, 19:01:11 »
Fink they were bigger.
But to directly answer your Q, no, sure I binned them......
« Reply #13 on: 30 December 2012, 09:36:37 »
Is that right? struggling to see any that small....
zirk
  • Epping Forest
« Reply #14 on: 30 December 2012, 10:14:51 »
From memory yea (Inside Hole dia), gave up with the web ones, so called Universal / One Size fits all, took old one off, measured it and poped down the local Auto Spares place, He had about 12 different sizes. Just got a pair that where the closest.
