Author Topic: 3.0lt gearbox problem  (Read 3072 times)
venom
  • South Moreton, Oxfordshire
« on: 29 December 2012, 13:16:30 »
Picked up our first caravan last night only a small 2 birth & on the motorway home it wouldn't select top gear under load but without the caravan there's no problems, so I'm puzzled any idea's  ???
Ken
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: 3.0lt gearbox problem
« Reply #1 on: 29 December 2012, 13:24:09 »
Worth posting up, Model, year, Engine size etc.
« Reply #2 on: 29 December 2012, 13:25:01 »
3.0ltr as per header Chris ;)
zirk
  • Epping Forest
« Reply #3 on: 29 December 2012, 13:28:08 »
What can I say Rob,  :-[  ;D ;D ;D
venom
« Reply #4 on: 29 December 2012, 13:34:22 »
1998 3.0 Elite Estate in met Green with cream leather with 5 spoke alloy wheels lol
Ken
zirk
  • Epping Forest
« Reply #5 on: 29 December 2012, 13:38:07 »
Sat Nav?  ;)
Im not an Auto Box Person but it could be something simple like an ATF check / change.
venom
« Reply #6 on: 29 December 2012, 13:40:23 »
Sat Nav?  ;)
Oh yeah forgot that, sat nav elec Windows & sunroof
Ken
venom
« Reply #7 on: 29 December 2012, 18:05:18 »
Took the caravan out again today just to make sure it wasn't a one off and it isn't, got it up to 60 & it just won't go in to 4th with the van on  ???
Ken
« Reply #8 on: 29 December 2012, 18:28:48 »
You sure the caravan's brakes aren't dragging?  :-\ :-\ I assume your car drives OK when not towing
« Reply #9 on: 30 December 2012, 09:43:58 »
The gearbox ECU does take a load input, so if its putting the engine under more load, will hold a lower gear.
Not sure if the caravanners can comment if the firmware updates are worthwhile on the 3.0l auto for towing?
« Reply #10 on: 30 December 2012, 09:49:14 »
Had my update before OOF started & before I resumed caravanning  :-\  :-\  :-\
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #11 on: 30 December 2012, 13:06:08 »
The problem seems to occur when the pikey house is attached,so in my professional opinion,the way to stop the problem re-occuring is dont tow a pikey house ;D
 one less on the road he hopes :)
Hoof'land storeman.
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #12 on: 30 December 2012, 17:25:57 »
My 3.2 holds third for miles when under load with the van on the back. My van weighs in at around 1600kg and anything other than flat ground forces it to drop down out of top gear. Quite frustrating at times as the mpg suffers. Mine does stay in top gear at motorway speed (60mph) when the load is 'rolling' on a flat road but the slightest incline knocks it down to third again.
The torque up hills is superb though.  ;)
Has it not gone in to top gear at all when towing Ken?  :-\
« Reply #13 on: 01 January 2013, 19:32:52 »
You can fool the system into dropping into 4th at 50 mph quite easily, just back off the throttle very gently and it will drop in.... then be light with the right foot and it will stay in 4th.... if you need to power up a hill or past something it drops to 3rd easily, you then repeat the process once past the obstruction.  Because the auto box "adapts" to the way you drive, if you are always heavy with the right foot it will learn to stay in 3rd, and can be difficult to coax out.... be gentle and it will soon "learn" to use 4th as well
And that's a 3.2 towing 1680 Kgs... :)
