Author Topic: 3.0 v6 ( lpg) misfire/lumpy tickover  (Read 1964 times)
idwal
  • telscombe cliffs near brighton
    • Mv6 estate (2000) Lpg
« on: 30 December 2012, 16:39:15 »
Hi - my 3.0 v6 with lpg (2000) has started to misfire.
it has a slightly lumpy idle and can be heard misfiring on tickover.
2 days ago it started to develop a stutter when driving - which would
cure itself after a few seconds,   sometimes it revs normally other times
stutters and then goes. (this is on both petrol and lpg).
I have done a paper clip test and,  with engine off is showing code 3-1
it goes through the 1-2 start up   then gives 3-1  and then  end 1-2?
31   No Engine RPM Signal - is this correct?
only other thing that has been done to car recently is I had a cat back stainless system
fitted which was bought off another OOF member  (sounds great)
can anyone suggest anything?
thanks
ken
Re: 3.0 v6 ( lpg) misfire/lumpy tickover
« Reply #1 on: 30 December 2012, 16:40:56 »
31 is normal without engine running, start with basics. Check plug wells for oil/water, when was the last time the plugs were changed?
idwal
« Reply #2 on: 30 December 2012, 16:50:53 »
I had rocker covers done earlier this year and think they were done then!
Will get plugs ect checked tomorrow
Thanks
Ken
idwal
« Reply #3 on: 31 December 2012, 15:25:12 »
 coil pack Changed - sign of water egress/damage
No more misfire :y
Ken
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #4 on: 31 December 2012, 17:48:50 »
Glad to hear its sorted Ken, hows the Exhaust system?
idwal
« Reply #5 on: 01 January 2013, 16:58:43 »
Exhaust sounds great ;D well worth the trip and great to put a face to name on forum.
will have too sort out a chipped ecu soon :y
Ken
zirk
  • Epping Forest
« Reply #6 on: 01 January 2013, 18:45:07 »
Ken
Good news Ken, try the Chip you already have, just needs a spare leg soldering to it from memory.
