Author Topic: Another coolant leak question.  (Read 5512 times)
Murph
  • Dartford, Kent
    • 2.5 Estate
« on: 30 December 2012, 20:58:11 »
I've had a persistent coolant leak on my 2.5 since I've had the car (about a year now!). In the spring I changed the HBV for a pattern part (I know!) which made no difference, so last weekend I got some new dowty washers and hollow bolts and got spannering.
I found that the old washers were pretty buggered and the bolts quite crusty, so I was confident that I would now have no more problems and topped up with antifreeze.
It's now worse!
I now have no heating at all and the coolant needs topping up every few days.  The car will overheat if sat in traffic even if the expansion bottle has plenty in it.  5 mins from home steam can be seen coming from the passenger side of the bonnet.
Today I got it warmed up and started investigating again and found water dripping down from the back of the engine, passenger side.
The water is mostly dripping from the engine/gearbox join and the crank sensor is wet.
So.... can anyone suggest anything up that way that I should be looking at?
  • Auckland
    • Mazda MPV
Re: Another coolant leak question.
« Reply #1 on: 30 December 2012, 21:18:39 »
That is where my 2.5 leaked when the head gasket started weeping (sorry :()
I drove it for months before finally doing a pressure test on the cooling system that confirmed it.
The rear of the passenger side (2,4,6) bank seems to be the only place where V6 head gaskets ever fail (and that doesn't happen often).
amba
  • Medway towns
    • German V6
« Reply #2 on: 30 December 2012, 21:28:26 »
Think mine may have a similar very minor leak as often can smell burnt coolant and level drops by around 3 cms over a 4-6 week period.
Every seal/washer and pipe has been replaced along with thermostat/coolant bridge/HBV/etc etc but still can,t cure it.
I have now come to the conclusion that at 14 years old and 215k under her belt she is entitled to being a little in-continent ;D so just keep an eye on the levels and top up as required :y
Big_Al
« Reply #3 on: 30 December 2012, 21:34:08 »
As you have changed the washers & bolts on the coolant bridge and the leak is now worse than before .
I would try & get a mirror on a stick down the back of the engine to see that after  all the pulling about etc. changing washers/bolts It is not a hose that is weeping /split worse than it was before .
There  are a few rubber hoses round the back there.  HBV /Heater etc.
Sorry cant be more helpful but would double check those first before you start worrying about a head gasket .
Pattern HBV  is a worry though  :-\
HTH    ;)
« Last Edit: 30 December 2012, 21:48:10 by Essex Big Al »
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #4 on: 30 December 2012, 21:52:21 »
Oil cooler plate or thermostat?
« Reply #5 on: 30 December 2012, 22:08:06 »
Did you notice a telltale stain or trail of coolant whne you had the manifold etc. off to do the dowty washers ?
If there was one it should have lead to the cooler plate or stat area ime,if not as Al said,check hoses etc. around the rear of the engine,and fit a genuine HBV while your in there imo.
  • Auckland
    • Mazda MPV
« Reply #6 on: 30 December 2012, 22:21:06 »
Do a pressure test on the cooling system. Any thing else is just guess-work.
Murph
  • Dartford, Kent
    • 2.5 Estate
« Reply #7 on: 30 December 2012, 23:15:09 »
Thanks for the advice so far fella's.
I forgot to mention... I pressure tested the coolant system today and it holds 2.3 bar with no drop over 10 mins.
With the engine running at fast idle the pressure rose to just over 2.5 bar (into the red on the gauge) and held there fine.
Still no heating after that!
Gaffers
« Reply #8 on: 30 December 2012, 23:25:28 »
a blocked heater matrix can cause the coolant flow to change and thus affect the cooling of the engine.  Hence the overheating.  Leak could be anywhere but I'd just check the unions of the pipes through the bulkhead.
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #9 on: 30 December 2012, 23:50:52 »
I think it has been proved that most head gasket failures where on 98 3.0 engines, 2.5 seem to be ok but hbv would be the first check then oil cooler plate and then the seal at the back of the engine block where the coolant transfer pipe joins the block.
Jaguar XJ6
« Reply #10 on: 30 December 2012, 23:58:56 »
Istr hearing of the occassional rusty core plug at the back of a head leaking. :-\
Big_Al
« Reply #11 on: 31 December 2012, 08:39:56 »
Did you try the pressure test   with both  heating on & heating off ?
As your leak has got worse since you changed the dowty washers & bolts . . i would be looking at something you have moved or pulled as you done that job  :-\ :-\
Get the scuttle off so you can have a better look down that rear engine area with it running.
 Probably do no harm to flush out the heater matrix as well
HTH
  • Auckland
    • Mazda MPV
« Reply #12 on: 31 December 2012, 10:14:11 »
Mine was a 1994 2.5
I suspect that coolant maintenance (or lack of) is more significant than the year of manufacture.
  • Auckland
    • Mazda MPV
« Reply #13 on: 31 December 2012, 10:19:37 »
You are not looking for a big leak. I doubt whether you will see a drop in pressure.
What I did was take the inlet manifold and trumpets off, plug the pipes to the throttle body, and then left it pressurised to about 1 bar /14.7 psi.
I left it for a couple of hours and then went looking for leaks.
Murph
  • Dartford, Kent
    • 2.5 Estate
« Reply #14 on: 31 December 2012, 11:32:14 »
Lots to think about, thanks.
I'll get in there and have a good look at the weekend now that I have a few ideas what to look for.
Page created in 0.033 seconds with 20 queries.
