Author Topic: Condensation inside after engine is turned off!  (Read 4083 times)
2woody
  • Northumberland
Re: Condensation inside after engine is turned off!
« Reply #15 on: 01 January 2013, 23:26:21 »
air con drain is directly above where the clutch would be on a manual car. Good luck.
by the way - how are you.....?
« Reply #16 on: 02 January 2013, 02:11:49 »
Leave the ac running full blast. You should see two puddles form either side if the gear box. If not, ac failed or blocked drains.
