Author Topic: remote central locking problem  (Read 1548 times)
lewis1
  • cork ireland
    • 2.2 omega
« on: 31 December 2012, 13:02:52 »
hi there. when i first got my 01 omega the central locking buttons on the keys work but the last two months it has stopped.. the light was still flashing on the keys but not working the locks or boot.. i replaced the battery just incase and checked the sensor was still in the right place. is it possible that the keys has lost the code ??? if so is there anyway of recoding without a computer???  thanks
  • Online Online
Re: remote central locking problem
« Reply #1 on: 31 December 2012, 14:06:31 »
... is it possible that the keys has lost the code ??? if so is there anyway of recoding without a computer???  thanks
Key in ignition, turn till the ignition light comes on, operate the lock button. All locks should lock & then immediately unlock. Your key should now be synchronised with the central locking ...... different from coding a key to the imobiliser.
lewis1
  • cork ireland
    • 2.2 omega
« Reply #2 on: 31 December 2012, 14:12:15 »
press the lock button on the key is it???
  • Online Online
« Reply #3 on: 31 December 2012, 14:30:08 »
yes ..... as above  ;)
lewis1
  • cork ireland
    • 2.2 omega
« Reply #4 on: 31 December 2012, 14:43:45 »
ah spot on worked perfect now ive one problem left that is the lock button on the key doesnt light up (broke) as is my spare so unlocking is not a problem now just locking.. i have another omega for spares is there anyway i can use its key which works perfect on that car can i code it to mine??? just tride the whole possition2 and press unlock or lock(unlock worked on mine) but no joy... is that a computer job??? :(
  • Online Online
« Reply #5 on: 31 December 2012, 15:17:12 »
....... is that a computer job??? :(
Unfortunately  ...... yes  :(
it could just be the switch that's goosed. If so, Martin Imber on here will probably be able to sort your originals for you ie replace the swiches on the pcb from inside.  :y
lewis1
  • cork ireland
    • 2.2 omega
« Reply #6 on: 31 December 2012, 15:29:26 »
perfect job thanks very much for your help much appriciated   :y
