Author Topic: Does anyone know...............  (Read 2047 times)
grain.ben
« on: 02 January 2013, 18:59:45 »
..........off the top your heads if the connector below is the same as the one for the telephone prewiring?
If so, is it taped up to the loom where the prewiring is?
Re: Does anyone know...............
« Reply #1 on: 02 January 2013, 19:17:37 »
The cellular aerial only goes as far as drivers kickpanel.
I assume you are fitting a bluetooth kit, therefore the external aerial isn't used.
grain.ben
« Reply #2 on: 02 January 2013, 19:22:33 »
Thanks TB.
The kit i have is a nokia 616 which has an aerial input because it can be used as a stand alone phone, there is a sim card holder inside the box, so you can have a permanent car phone, OR connect your phone via BT
Have a look at this.............. http://nds1.nokia.com/phones/files/guides/Nokia_616_UG_en.pdf
grain.ben
« Reply #3 on: 02 January 2013, 19:27:04 »
Here you go, just to confirm..................
