is cleaning your injectors this easy?
Started by Webby the Bear, 02 January 2013, 23:16:02
Webby the Bear
http://www.youtube.com/watch?v=bKGI9N_yWd0
Now I've watched this guy on the tube for ages and in all honesty he's a bit of a 'tard. However, is this product or simlar available? I'm thinking that this would also clean out the carbon in the cylinders too, afterall, that's where the cleaner will end up  :y
RIP Paul Lovejoy
Quote from: Webby the Bear on 02 January 2013, 23:16:02
original carbon clean procedure takes more than half an hour if I remember correctly..  not sure the amount of fluid in that apparatus will be adequate for proper cleaning.. if we neglect the cars age..
the other items may help if used regularly and from young ages of car imo..
Webby the Bear
Quote from: cem on 02 January 2013, 23:28:02
this stuff it appears is simply added to a full tank of fuel and away you go. looking at a bunch of reviews people have had some good results....just trying to do as much to avoid spending the dosh on professional sonic cleaning. its only £5.99 a bottle and im going in for some wynns lifter treatment so i'm going to pick some up i think. whats the worst that could happen?? (touches wood, crosses fingers as this is an omega  ::) ::) ::) ::) ;D)
RIP Paul Lovejoy
Webby the Bear
sorry cem, just realised you were talking about the video. yeah, it also looks like you need special apparatus. going to go with the wynns option first
RIP Paul Lovejoy
Quote from: Webby the Bear on 02 January 2013, 23:32:39
We should get shares in wynns  ;D
Never seen anything like what scotty was using , just the stuff you put in the fuel tank  :-\
Webby the Bear
if that don't work i'm going for some ''start, you bastard'' hahahaha
http://www.youtube.com/watch?v=cY1YndLmbXQ
RIP Paul Lovejoy
I've used the Wynns injector cleaner over the years - usually about once a year and initially do notice beter response and increased smoothness.
doz
I had the injectors on the LC ultrasonicly cleaned when I rebuilt the engine. After a 100k miles the injectors were hardly blocked at all. Modern fuels don't tend to gum the injectors.
Wynns, a tank or two of decent fuel and a good thrashing can all help stave off the early symptoms of the dreaded precat codes :y
Ultrasonic is the proper way.
Wonder if bro will let me borrow one of his jewellery cleaners ::)
Quote from: TheBoy on 05 January 2013, 09:47:32
Indeed, and more importantly a decent service will give you a before and after report on flow rate and spray pattern so it will tell you if you did have a problem.
I've only bothered on a rare set I salvaged from a scrap yard, previously fitted to a Volvo with intergalactic miles. Even then, the injectors weren't too bad in the "before" report. They were spot on manufacturer's spec in the "after", though. I certainly wouldn't bother on a car that's getting regular use unless I suspected a problem.
this stuff it appears is simply added to a full tank of fuel and away you go. looking at a bunch of reviews people have had some good results....just trying to do as much to avoid spending the dosh on professional sonic cleaning. its only £5.99 a bottle and im going in for some wynns lifter treatment so i'm going to pick some up i think. whats the worst that could happen?? (touches wood, crosses fingers as this is an omega  ::) ::) ::) ::) ;D )
bottle cleaners are meaningful when you use them from the car is new.. but on an aged car they are a waste of money imo..
