Pages: 1 [2] 3  All   Go Down
Author Topic: MOT Fail - Steering play  (Read 7955 times)
Re: MOT Fail - Steering play
« Reply #15 on: 04 January 2013, 17:30:24 »
I replaced one on my omega and it failed the MOT the next day for excessive play. Was it a genuine/lemforder type or a generic one ?
« Reply #16 on: 04 January 2013, 17:35:45 »
Lemforder .. another thing I'll check in the daylight... 'tis a tad dark to be doing anything now !!
« Reply #17 on: 04 January 2013, 17:59:47 »
Wouldnt have thought a lemforder would have worn out in that time,but you never know.Very unusual for a steering box to have enough play to cause an MOT failure though. :-\
sassanach
  • trowbridge
« Reply #18 on: 04 January 2013, 21:13:51 »
i "thought"that you were allowed 3" slop at the wheel on a steering box system:?
« Reply #19 on: 04 January 2013, 21:19:48 »
It should be an easy check for you then nige, try with engine off and with engine on,
And yes sassanach, you are right it is 75mm for a non rack and pinion setup ( or no Land Rover would ever pass, not even a new one).
I would make an enquiring call to the mot guy regarding the allowable play given a non rack and pinion setup
hercules
  • sunnyudders
« Reply #20 on: 04 January 2013, 21:51:21 »
Must be the tester, steering on my 2.2 is about as tight as Jordons legs. 160k old wishbones, 60k old nackered idler arm. Still passes MOT with ease though!
how dare you insinuate that jordan is anything but a fine english rose,shame on you mark  ;D
« Reply #21 on: 04 January 2013, 22:30:12 »
Dug out the failure reference ..
2.2.A.1a  Steering system has excessive free play detected at steering wheel (steering box fitted)
and my "quickie guide" lists this as ..
http://www.motuk.co.uk/manual_220.htm
which implies to me he thinks there is more than 75mm of play ??
At least it gives me something to check in the morning.. :)
would a "tweak" of the steering box thingie tighten it up at all ?? If it is easy to do I'm thinking of a 1/4 turn before the test then back it off after ...  :)
If it is thought a good idea :) .. then how do I access this adjustment ?? or is it obvious ??
« Last Edit: 04 January 2013, 22:33:08 by Entwood »
« Reply #22 on: 05 January 2013, 03:16:48 »
Worst case, put a smaller diameter wheel on for the MoT. 75mm will go alot further with a smaller radius :y
sassanach
  • trowbridge
« Reply #23 on: 05 January 2013, 11:41:54 »
if you have 3" of slop at the steering wheel i would be suprised,chances are you have a balljoint or something with slop in it.do not adjust the steering box unless the slop is in the steering box itself
« Reply #24 on: 05 January 2013, 11:58:12 »
 ;D ;D ;D ;D
Taxi_Driver
« Reply #25 on: 05 January 2013, 12:09:18 »
Do you need a hand with this Mr E? I can be free this afternoon.....
I probably wont be a lot of use......but i could at least twiddle the wheel whilst you look for play  :-\
« Reply #26 on: 05 January 2013, 13:15:46 »
If it had 75mm of play you would know it!
« Reply #27 on: 05 January 2013, 13:43:54 »
Without a doubt you'd know it. It would be impossible to drive at 30, never mind 70.
« Reply #28 on: 05 January 2013, 16:37:39 »
Well, spoke to Mike about it this morning ... he said, with the engine running put a bit of masking tape at the top of the steering wheel with the wheels central, then very gently turn the steering wheel until the road wheels JUST move, place another piece of tape at the top of the steering wheel.... harsh movements will give a false indication. Repeat in the other direction. Measure the distance between the outer pieces of tape. Max allowed is 7.5 cm
Did all that and was exceedingly surprised that the measurement was 8.2 cm !!!!!
Used the adjuster on the box and with a shade under 1/2 a turn the distance is down to 4.7 cm. If I go above 1/2 a turn the "self centering" of the steering when driven is poor.
I must admit that the whole steering now seems much firmer/more positive, but whether that is just the adjustment made, or a combination of the adjustment and the new boots all round, or a placebo effect I can't be certain. I also wonder if my comments about "tramlining" are actually a mixture of the slop and the old tyres.....
Car goes back Monday to be re-tested.
I totally accept the above comments about being undriveable, and was VERY surprised at the measurement .. I would have thought the car undriveable as well .. but it seems that the hydraulics have the ability to mask the problem somehow, so that it only fully shows with gentle movement of the steering.
I wonder what Mike will say on Monday !!!  :)
« Reply #29 on: 05 January 2013, 19:30:44 »
Plus, as it has gotten gradually worse you probably haven't noticed as much ;)
Pages: 1 [2] 3  All   Go Up
