Do's and don't colour coding parking sensors.
Started by Auto Addict, 05 January 2013, 09:56:37
Auto Addict
Bought a set, they're shiny black.
Any do's and don'ts as regards painting them?
I like red cars
I have a painted set on clit.. a normal thickness paint dont make any problem..
however, if the car is dark color no painting required imo..
Auto Addict
Quote from: cem on 05 January 2013, 10:00:08
Got to change them to silver lake.
I like red cars
Auto Addict
I thought I would rub them down with some 1200 wet & dry, thin coat of plastic primar.
2 thin coats of Silver Lake, 1 coat of laquer.
I like red cars
I used a kitchen scourer on my pattern ones.  That said, one has now pitted.
Auto Addict
Quote from: TheBoy on 05 January 2013, 10:20:21
Yes, did the same on my old ones, and hand painted them.
Problem was the paint went on a bit thick.
I like red cars
I sprayed mine - mounted them all in some card, and sprayed one "swipe" at a time, about 5 coats IIRC (it was a long time ago).
I mounted card, with sensors mounted, it a ice cream tub, and put the lid on after every spray, to keep dust out.
Probably best done indoors as well if possible, if only to minimise the temperature and humidity issues of our delightful weather :y
Auto Addict
Quote from: ex taxi al on 05 January 2013, 10:38:09
I like red cars
Olympia5776
Done it many times.
I just cleaned them using diluted APC ( all purpose cleaner ) and allowed to dry off thoroughly .
Get a small box and use the hole cutter supplied to cut four holes in it to mount the sensors for painting . Let them sit about 6mm proud of the surface to ensure paint covers all the sensor.
Paint them in a warm enviorment best about 18 degrees at least . As suggested a light covering of white primer and then two or three "mist " colour coats until you get coverage , dont put too much paint on them. . Allow to cure /dry and then three or four " mist " coats of lacquer . Best tip I can give you is use good lacquer . When using aerosols I always use U pol clear No 1 which has never let me down . You can flat the lacquer down and polish if required using 1500 wet & dry if neccessary but you probably won't have to . Again allow the lacquer to cure by leaving them in the cardbox on top of the HW tank for 12-18 hours .
