Author Topic: 2.2 auto gear box change  (Read 3719 times)
dazza88
  • luton (bedfordshire)
    • 2001 2.6 v6 auto omega
« on: 05 January 2013, 14:22:55 »
Hi guys.
Just wondering if any of yous have changed an auto box for a 2.2 if so is it hard as this will be my first time il be changing an auto ive looked under it and it dont look to bad to do i took it to my auto gear place and they want hundreds to to take apart and repair while i can get a box for around 150 and hopefully fit myself. Any help would be great thanks to all.   :y
2002 2.2 cd auto             mrk2 astra gte
vauxhall colton               vauxhall omega 2.6 v6 auto
ford sierra saphire 20l   vauxhall omega 2.2 dti 02 plate
Re: 2.2 auto gear box change
« Reply #1 on: 05 January 2013, 14:24:20 »
Why do you want to change it, whats wrong with current one?
dazza88
« Reply #2 on: 05 January 2013, 14:26:55 »
My current one seems to slip in 1st gear it gets the bit then revs then it sort of  juders i would rather get this one repaired but garage asking for silly money. :-(
« Reply #3 on: 05 January 2013, 14:33:20 »
Have you checked the fluid level?
dazza88
« Reply #4 on: 05 January 2013, 14:34:58 »
I havnt my self but the garage did say the fluid was fine but i would like to look myself. How do i see the fluid level plz mate
dazza88
« Reply #6 on: 05 January 2013, 14:59:38 »
Cheers mate  :y but sounds compicated lol. Is there not like a clear bubble thing im looking into
dazza88
« Reply #7 on: 05 January 2013, 15:02:26 »
Also if oil was low would that muck up the other gears or not. This is first time ive had probs with an auto. :-(
« Reply #8 on: 05 January 2013, 15:07:03 »
Yes low oil would cause gearing problems, no bubble or dip stick to check, as per guide  :)
dazza88
« Reply #9 on: 05 January 2013, 15:17:19 »
Cool cheers mate. So if i over flow it it will just come back out the hole.i will have ago tomoz bit late to start now. Dont surpose theres any pics of the 13mm plug u undo. Also do i remove the 13mm bolt out so i can poor the bottle in
« Reply #10 on: 05 January 2013, 15:23:50 »
Yes.
Bolt on drivers side, easy to spot.
Yes
dazza88
« Reply #11 on: 05 January 2013, 15:27:54 »
Top man thank you mate. Hopefully that might solve the prob. The garage said it was fine because it drives through the other fine
« Reply #12 on: 05 January 2013, 15:45:43 »
Main problem removing/refitting auto box its weight - its very heavy and ideally a helper + a good strong trolley jack is required.  Remember to remove torque convertor with box - do not leave on engine!!
dazza88
« Reply #13 on: 05 January 2013, 17:13:32 »
quote author=dbug link=topic=110724.msg1389692#msg1389692 date=1357400743]
[/quote]
Yep cool no worries  :y cheers mate ive got 2 helpers on hand and a 10 ton trolly jack ;-). Hopefully topping it up might solve the prob but if not it will be a new box are they hard to do and were abouts is the torque converter located on the box many thanks
Darren
2woody
  • Northumberland
« Reply #14 on: 06 January 2013, 20:47:28 »
just make sure that you get the torque converter that cam with the transmission you use. Manufacturers have a habit of changing the TC internals without changing the part number.
