Author Topic: y32se help  (Read 2759 times)
chev383
  • australia
    • holden vectra
y32se help
« on: 07 January 2013, 12:25:47 »
 hi any one out there have the diagrams for doing the cam timing or top end rebuilds on a y32se?it  has a blown head and i need to see what im  up against before starting i live australia and info on this motor is scarce any info would be appreciated  :)
b4ndit
Re: y32se help
« Reply #1 on: 07 January 2013, 12:28:24 »
Hello and welcome to the forum, have a look in the maintenance guides you should be able to find something in there :y
Re: y32se help
« Reply #2 on: 07 January 2013, 12:30:39 »
Same procedure as for the X25Xe, X30XE and Y26SE.
Some info in the maintenance guide area.
I would be looking to confirm head issues as its rare adn these have steel head gaskets, very worthwhile describing the symptoms (e.g. oil in the water which is very much NOT head gasket)
chev383
  • australia
    • holden vectra
Re: y32se help
« Reply #3 on: 07 January 2013, 12:47:29 »
engine seemed to be running fine but after 1 half minutes smoke was coming out the exhaust the intake manifold was full of oil and thats as far as iv got.first thought it was a blown head pressurising the oil system and pushing it thru the pcv any thoughts?
Re: y32se help
« Reply #4 on: 07 January 2013, 16:14:24 »
Check leaking cam covers (+ breathers probably blocked) or leaking connectors to oil cooler (sat in the V) - as said very unlikely to be HG on these!  Lot less hassle and less cost to fix these vs changing hgs :y
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: y32se help
« Reply #5 on: 07 January 2013, 23:00:32 »
Some 3.2 vecta in service did have headgasket faiiure due to the back bank 135 getting hotter due to airflow and coolent temp after a long hard drive then just being switched off,.
Hoof'land storeman.
Re: y32se help
« Reply #6 on: 08 January 2013, 00:42:43 »
Transverse engine!
biggriffin
Re: y32se help
« Reply #7 on: 08 January 2013, 09:42:10 »
Looking at the op profile he has a holden vectra hence my post regarding transverse headgasket failures.
Hoof'land storeman.
Re: y32se help
« Reply #8 on: 08 January 2013, 17:11:52 »
Sorry mate assumed it was an Omega ;)
chev383
  • australia
    • holden vectra
Re: y32se help
« Reply #9 on: 09 January 2013, 06:30:48 »
nah its a 04 holden vectra think your omegas over here are holden commodores but you can get ls1 motors in them which would be a pontiac gto in the states. gm love playing name games.thanks for all the replies great help.
Jan Suhr
  • Nyköping, Sweden
    • 2 Omega Caravans 3.2 V6
Re: y32se help
« Reply #10 on: 09 January 2013, 18:57:31 »
Wish they have sold them with the LS1 over here.
Infact Opel made a prototype that was shown at the Frankfurt Autoshow in 2001. Project was cancelled in the last minute due to over heating problems when going full throttle on Autobahn. It also had 13" Corvette brakes in front.
The Holden Commodores ar a few inches wider and can handle the V8 a little better.
Jan
Jan Suhr
Stockholm, Sweden
www.protouring.se
