Author Topic: Front Bumper  (Read 3044 times)
Front Bumper
« on: 07 January 2013, 12:43:38 »
The screw that holds it in the wheel arch has ripped a small hole so now its flapping about , cant see how i can fix it , i was going to pop rivet it but see nothing to pop it to  :( Anyone repaired one  :-\
Argument with a curb that got pulled underneath when i reversed  :-[
« Last Edit: 07 January 2013, 12:46:23 by EMD »
Re: Front Bumper
« Reply #1 on: 07 January 2013, 16:16:18 »
Whoops  ::)
Re: Front Bumper
« Reply #2 on: 07 January 2013, 16:29:57 »
There's a plastic trim under the bumper that screws along the wing, sounds like that had broken, the good news is, it's easy to replace ;)
Re: Front Bumper
« Reply #3 on: 07 January 2013, 18:56:37 »
Ill try and get a picture up tomorrow to show what i mean , difficult to explain in words . Just as well the curb was loose or it would have pulled the bumper off  ::)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Front Bumper
« Reply #4 on: 07 January 2013, 20:14:29 »
The bottom section of my rear bumper was flapping downwards following me stupidly losing two of the pushplugs  ::).... nothing a couple of zip ties didn't cure.... cant remember if you have access round the side of the inner flap to get a cable tie in but if you can... job done  :y
RIP Paul Lovejoy
Re: Front Bumper
« Reply #5 on: 08 January 2013, 14:52:35 »
Here is the picture , not sure how to go about fixing it  :-\
Re: Front Bumper
« Reply #6 on: 08 January 2013, 14:56:01 »
Pop the bumper off. You should see a plastic bracket on the wing between the wheel arch and the front of the wing. Replace this and reassemble :y
Re: Front Bumper
« Reply #7 on: 08 January 2013, 14:57:31 »
Does it matter that the liner has torn  :-\ The bracket you mention , is that the one that the rusty screw is fixed to in the picture ?
« Last Edit: 08 January 2013, 14:59:20 by EMD »
MV6Matt
  • London
    • No car since 2022....
Re: Front Bumper
« Reply #8 on: 08 January 2013, 15:09:58 »
Yes, it does.
Had same problem on mine.
You can also see the one in the wheel arch lining above has gone also.
My solution was to put an additional screw in next to the rusty one at about a 45 degree angle. This has held firm on my without any further movement.
The bracket mentioned are easy to replace if you want to (as has already been suggested.) They are sided so make sure you get the correct side. I got mine from Omegaspareparts.
HTH
Matthew
(thanks Ian)
Re: Front Bumper
« Reply #9 on: 08 January 2013, 15:12:07 »
Whilst not ideal, the liner isn't a big problem as it clamps between the bumper and the bracket.
The bracket is visible in the pic between the bumper and the wing. It will be screwed/rivetted to the wing in 3 places iirc. The screw goes through the bumper and the liner, and into either a threaded clip which the old screw is probably rusted to, or it screws straight into the body of the bracket, but I can't remember which without looking.
Re: Front Bumper
« Reply #10 on: 08 January 2013, 15:16:05 »
Either way then ill have to try and get the old screw out , mite have to saw it off and drill it .
Hope i got that right , thanks for the tips  :)
Re: Front Bumper
« Reply #11 on: 08 January 2013, 15:23:45 »
Saw the head off, and then molegrips :y
Re: Front Bumper
« Reply #12 on: 08 January 2013, 18:41:46 »
Will do thanks again  :y
