Author Topic: WTD: 2001 3.0 Manual ABS ECU  (Read 5699 times)
Re: WTD: 2001 3.0 Manual ABS ECU
« Reply #15 on: 11 January 2013, 21:33:29 »
Just my 2p's worth .. a second hand unit may well be about to fail in exactly the same manner as your old one ... there is no way of knowing .. for that reason I had mine (on the old 2.5 ) repaired ... no need to worry about configuration as it is "your" ECU .. and it came with a 2 year warranty .... £130 then don't know how much now...
Worth a thought ?
Depends on budget imo.Second hand is a gamble,but £100 cheaper than a repair,so if someone is running the car on a tight budget (as many are these days) they may consider second hand more viable for them.
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
« Reply #16 on: 11 January 2013, 22:23:27 »
I may be wrong, but.....
I believe that provided the part numbers are identical, then it would fit any version using that part. Example is I bought a second hand one from DLK that came from a 3.0ltr, fitted it to my 2.5ltr, then TB programmed it for my 2.5ltr and its perfect :y
« Reply #17 on: 11 January 2013, 22:34:41 »
That's the nub .. if it is NOT from the same engine/transmission/body type (?) then it needs re-configuring via tech2 .. and not everyone is close to a tech2 .. :(
so same config or repair to get around the config issue
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Hoof'land storeman.
« Reply #19 on: 11 January 2013, 23:00:33 »
« Reply #20 on: 12 January 2013, 10:40:55 »
I had mine done here ..
http://www.bba-reman.com/catalogue/Product.aspx?product=2959
I have known them to destroy an ECU, so clearly they don't always test them after.
Page created in 0.072 seconds with 20 queries.
