Pages: [1] 2 3  All   Go Down
Author Topic: Changed out HU  (Read 8809 times)
Ninda
  • Slough
    • 2.6 CDX 03 + 3.2 Elite 03
Changed out HU
« on: 11 January 2013, 13:37:06 »
Hey guys i changed out the HU on my Elite, and i realised that now i cannot control the cars own screen, it says Brake light check, so i do that, then it comes up with Icey Roads. Is there anyway for using it now ?
And also quick question of changing the speakers, can i use the original Wiring and just change the speakers? As i have all the speakers that i hope will fit in the front doors and back doors, and as for the back shelf ill buy some for there too :D.
  • Auckland
    • Mazda MPV
Re: Changed out HU
« Reply #1 on: 11 January 2013, 16:22:59 »
Which car?
Which model is the old HU?
Does it have BOSE?
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Changed out HU
« Reply #2 on: 11 January 2013, 16:48:23 »
OP says Elite so Bose, have you left the Amp in?
Have a read here http://www.omegaowners.com/forum/index.php?topic=97131.0
Ninda
  • Slough
Re: Changed out HU
« Reply #3 on: 11 January 2013, 18:01:39 »
Sorry guys for the lack of information was in a rush on my way out. The car is a Vauxhall Omega, 2003 3.2 Elite
The original headunit is a Siemens NCDC 2013, and yes it has a Bose Amp, which i think is connected to all 6 Speakers in the car :D
And yes i have removed the Amp now.
« Last Edit: 11 January 2013, 18:04:41 by Ninda »
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: Changed out HU
« Reply #4 on: 15 January 2013, 19:15:15 »
Read the sticky at the top of this section regarding bose and aftermarket Hu, Thats what it is there for.
Jaguar XJ6
Re: Changed out HU
« Reply #5 on: 16 January 2013, 16:27:49 »
Ninda
  • Slough
Re: Changed out HU
« Reply #6 on: 21 January 2013, 14:13:55 »
OK thanks, i have read it, and i have replaced the speakers and put my own cables in, but now i have another problem
I disconnected the wiring loom in the driver door, and the reconnected it, turned the car on then the airbag light came on. So i turned the car off, then back on, the airbag light turned off, but then 2 seconds later the light comes back on. Does it need to be reset? And how do i do that?
  • Auckland
    • Mazda MPV
Re: Changed out HU
« Reply #7 on: 21 January 2013, 20:55:27 »
Once the airbag system has detected a fault it requires a session on Tech2 to clear it (sorry).
Ninda
  • Slough
Re: Changed out HU
« Reply #8 on: 22 January 2013, 20:20:51 »
  • Auckland
    • Mazda MPV
Re: Changed out HU
« Reply #9 on: 22 January 2013, 22:06:33 »
Possibly...
I would recommend http://theboy.omegaowners.com/tech2/prices.shtml  :y
Ninda
  • Slough
Re: Changed out HU
« Reply #10 on: 23 January 2013, 16:46:37 »
OK thanks a lot Andy H mate :), ill have a look :D
Thanks to everyone here helping me !!!
Ninda
  • Slough
Re: Changed out HU
« Reply #11 on: 31 January 2013, 17:58:43 »
Hey guys, Amps all fitted, sound is good :D, BUT im having Radio interference with one of the amps i used. I have a 2 Channel Amp, and a 4 Channel Amp, and the 4 Channel amp seems to be at fault as when i disconnect it the Radio works fine, no interference issues :D, But as soon as i connect the 4 Channel amp back up again, the Radio doesnt work properly.
I have tried different cables(e.g Power Cables, Earth Cable, Remote/Trigger Cable), and also tried moving amp, from right under the parcel shelf to the floor, its just that amp keeps interfering with the Radio.
Any suggestions ?
ffcgary1
  • Mitcham,Surrey.
Re: Changed out HU
« Reply #12 on: 31 January 2013, 22:42:18 »
Is it a bose amp under the parcel shelf?
If so that will be the issue but Dave dnd will be the man to advise more.
Jaguar XJ6
Ninda
  • Slough
Re: Changed out HU
« Reply #13 on: 01 February 2013, 11:03:53 »
Hmm its a Vibe Amp :(
And i have heard of Dave's magical work :D, i shall pm him :D
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Changed out HU
« Reply #14 on: 01 February 2013, 11:09:36 »
Any chance of some images of the setup connections - may be easier to see what you are doing?
Gut feeling is that you have a poor earth connection to the body, insufficient power to the amps and a remote feed that may be under voltage.
What had unit are you running?
Is the interference just on radio?
Is the interference with engine running or not?
Radio & Decoding Technician
www.dndservices.co.uk
Pages: [1] 2 3  All   Go Up
