Pages: 1 2 3 [4] 5 6 7 8 9 10 11   Go Down
Author Topic: Battery light on  (Read 32702 times)
Re: Battery light on
« Reply #45 on: 14 January 2013, 07:59:17 »
Thanks Rob, are all 3.2 alternators the same? :-\
the spare I have is off an mv6 3.2. Customer spec. Will that part number do.?
Not sure Chris, may be worth contacting seller.
VX part # for the 120A is BR14-T3-V14 or there`s these
http://www.woodauto.com/Component.aspx?Ref=VRG46418  (unbranded)
http://www.woodauto.com/Component.aspx?Ref=VRG46479  (Bosch)
« Reply #46 on: 14 January 2013, 08:00:16 »
I need to get a meter on it later, but could the fix be as simple as this dodgy contact shown in the bottom pic?
http://www.omegaowners.com/forum/index.php?topic=90512.0
Quite possible, had one like that, good clean and was OK for about a year
« Reply #47 on: 14 January 2013, 08:09:04 »
Those later alternators are not as reliable as the early ones and I seem to recall the regulator chip having some intelligence so it chucks the light on bright when the output drops (so check the rectifier diodes to).
As for distance. I have towed a dead Omega 80 miles on a partialy charged battery at night and the engine is not a huge consumer.
« Reply #48 on: 14 January 2013, 08:27:36 »
My regulator came from MURE. Worth getting the bearings too, and doing a proper refurb, if it's the reg. that has failed.
The receipt was around somewhere <rummage>.
As said, I've got an alternator ready to go if required urgently. :y
Radar
  • Berkshire
    • Elite 2.5 Auto
« Reply #49 on: 14 January 2013, 14:32:28 »
Just a word of thanks to Radar btw. :y
Turned my phone on this morning ,after the battery died at the crucial moment last night, and was quite touched to find texts and voice mail from him offering a jump start if needed.
What a true gent.
Thankyou to Radar.
H and Chris.  :-*
Thankyou, your most welcome - the good thing is you got home :y :y
« Reply #50 on: 14 January 2013, 14:36:17 »
Mark, have you seen who your talking to? :-[  ;D
« Reply #51 on: 14 January 2013, 14:37:22 »
What a true gent.
Thankyou to Radar.
H and Chris.  :-*
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #52 on: 15 January 2013, 07:20:52 »
Home now. Piece if piss. Didn't skip a beat.
Jump leads for a while then went for it. Electrics seem fine, although the alarm went off moving mine nearer to Dads merc. Which reminds me, it did exactly the same thing on Boxing Day morning after a lay up of 3 days. Power sounder went off for 30seconds, couldn't turn it off. Presume its seeing low battery voltage and thinks the battery is being disconnected or whatever.
Battery is a "go" job with a very very black indicator.
Where do I get a regulator from for these alternaters? I have a spare alternator somewhere, so will recon my one while its off the car if possible.
There were a load of Go batteries produced with faulty indicators, if you take it off and give it a shake, it may glow green.
I like red cars
« Reply #53 on: 15 January 2013, 09:19:15 »
Shake it? Bloody throttle it! ;D
I do wonder if this explanes the grumpy running on gas from cold. Cold also meaning a low charge in the battery. :-\
« Reply #54 on: 15 January 2013, 12:28:16 »
It's a truely shite lpg system if it can't cope with a supply that is a volt or so lower
« Reply #55 on: 15 January 2013, 13:51:35 »
I think it's wishful thinking ::) Mine ran fine on the saloon and I had battery crimp issues that dropped voltage to 12V when all electrical loads were on and it was fine ;)
« Reply #56 on: 15 January 2013, 14:16:55 »
It was showing 11.2 volts on the meter.
« Reply #57 on: 15 January 2013, 14:51:27 »
If I'd actually read this thread (I ignored it and didn't look at who posted it as I figured it'd be a simple question already answered) I'd have said you were welcome to stop in on your way back for a top-up..
But I didn't. So you weren't.  :P ;D
« Reply #58 on: 15 January 2013, 17:04:14 »
My LPG setup was working perfectly until everything else gave up when my alternator packed in. :-\
Ditto, and if you'd said where you were going from and to it might have been handy. ::)
« Reply #59 on: 15 January 2013, 18:31:01 »
See, I said leave him stranded...  (as long as Mrs CG wasn't with him, as she'd whollop me)
Pages: 1 2 3 [4] 5 6 7 8 9 10 11   Go Up
