Author Topic: NCDC GPS aerial connector type?  (Read 6934 times)
twiglet
  • Norwich, Norfolk
« on: 14 January 2013, 15:37:27 »
I need to buy a couple of GPS aerials for NCDC's (the 2 inch, black, square type)...
Can someone remind me what type of connector they have, and whether they are male or female, as I'll be buggered if I can remember...  ::)
An ebay link would be even better...  :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: NCDC GPS aerial connector type?
« Reply #1 on: 14 January 2013, 15:44:53 »
Fairly sure there FME's.
Probably got a male and female connectors kicking around somewhere you can have James, but you need the Crimp Tool (which I have but cant afford to Post it out / needed for work).
Chris.  ;)
Edit:, Im talking about the Foot Well James is this the same?
« Last Edit: 14 January 2013, 15:47:16 by zirk »
twiglet
  • Norwich, Norfolk
« Reply #2 on: 14 January 2013, 15:47:34 »
Chris.  ;)
Cheers Chris.  I'm sure they were only about a fiver on ebay last time I looked, so no worries there.  Just need to find the right one.  :y
I might ask you to make up a length of sky cable for me in the not-to-distant future though, if you have all the bits?  ;)
zirk
  • Epping Forest
« Reply #3 on: 14 January 2013, 15:48:47 »
James, read my Edit above.  :y
twiglet
  • Norwich, Norfolk
« Reply #4 on: 14 January 2013, 15:49:31 »
The aerials I'm thinking of are designed to be placed in the corner of the windscreen, and have a couple of metres of cable with a connector on the end, that plugs straight in the back of the head unit.
zirk
  • Epping Forest
« Reply #5 on: 14 January 2013, 15:52:15 »
To go in the back of the HU then, cant remember them.
zirk
  • Epping Forest
« Reply #6 on: 14 January 2013, 15:54:56 »
No worries, most of my stuff is 50 Ohm, but the 75 Ohm Sat stuff you dont need tools for.  :y
twiglet
  • Norwich, Norfolk
« Reply #7 on: 14 January 2013, 16:01:36 »
Was hoping you could make me up a double cable, with the connectors on, ready to run direct from the LNB to my freesat box in my garage.  It will be about a 40 metre run...
« Reply #8 on: 14 January 2013, 16:24:47 »
SMB male IIRC
« Reply #10 on: 14 January 2013, 17:10:31 »
Christ on a crosstrainer,Ive heard it all now !  ::) :D ;D
twiglet
  • Norwich, Norfolk
« Reply #11 on: 14 January 2013, 17:58:16 »
Probably have to "modify" the cage James
http://www.ebay.co.uk/itm/GPS-Antenna-5M-Male-SMB-Magelian-Trimble-Lowrance-AVmap-/270626678420?pt=UK_In_Car_Technology&hash=item3f029b6694
Cheers Rob, that's the kiddie!  :y
IIRC, the last one I used had 180 degree (straight) connector, so it was just a case of feeding it through the cage and then pulling it back slowly as I pushed the headunit home.  :y
twiglet
  • Norwich, Norfolk
« Reply #12 on: 14 January 2013, 17:58:53 »
You don't know the half of it mate!  ;) :-X ;D
Vega
  • The Netherlands
    • Omega Saloon 3.2
« Reply #13 on: 14 January 2013, 18:16:27 »
SMB male IIRC
No.
Connector on the HU is MCX.
The original connector near the roof areal is fakra.
twiglet
  • Norwich, Norfolk
« Reply #14 on: 15 January 2013, 23:22:09 »
SMB male IIRC
No.
Are you sure it's not an SMB type Peter?  I've never heard of the MCX type before, although a quick ebay search showed it looks very similar to the SMB type.  :-\
