Author Topic: finally found my leak!!!!  (Read 3681 times)
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
Re: finally found my leak!!!!
« Reply #15 on: 15 January 2013, 17:56:04 »
somewhere in the engine bay ;D ;D
closest so far ;D ;D
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #16 on: 15 January 2013, 17:57:04 »
hbv then?
RIP Paul Lovejoy
« Reply #17 on: 15 January 2013, 18:02:43 »
Radiator drain tap :-\ ;D
plym ian
  • Plymouth, Devon
« Reply #18 on: 15 January 2013, 18:35:34 »
ok I tell you all....
'twas the smallest crack in the top of the radiator where the top hose joins.
took me well over an hour to find :(
next question is how much is a new radiator and best place to acquire one
Webby the Bear
  • Northampton
« Reply #19 on: 15 January 2013, 19:10:36 »
thought it was at back of the block?  ???
RIP Paul Lovejoy
« Reply #20 on: 15 January 2013, 19:25:09 »
[/highlight]
Have a look at this, mine has gone in exactly the same place and I bought this one. It is still sitting on my dining table waiting for the snow to burger off but it looks a very well made pukka bit of kit for not a lot of wonga! :y
http://www.ebay.co.uk/itm/VAUXHALL-OMEGA-2-0-2-2-2-5-3-0-cc1994-2003-AUTO-MANUAL-NEW-RADIATOR-/190779851811?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2c6b5d8423
Abiton
« Reply #21 on: 15 January 2013, 19:46:07 »
On the 4-pots, it may be worth checking that there isn't excessive movement on/of the engine mounts, when this rad failure occurs. The top hose being quite short, I could imagine that if the engine is rocking side-to-side too much on its mounts, some of that energy may end up being transferred by the coolant hose, and end up stressing the area of the rad where these failures seem to happen.
Difficulty is judging how much movement is too much, I guess.  Can't remember whether rad failure happened before or after I discovered that one of our engine mounts was an unholy mess of torn rubber.
plym ian
  • Plymouth, Devon
« Reply #22 on: 15 January 2013, 20:05:25 »
hmmm could be something in that. have noticed a knock noise on initial start up dosnt sound like a metal knock but haven't really investigated that fully.
cheers philrich saw them on there earlier. most secondhand ones aren't much cheaper than that.
Page created in 0.037 seconds with 16 queries.
