new tyres/balance weight
Started by Andy B, 18 January 2013, 17:32:55
Quote from: Lazydocker on 18 January 2013, 18:29:30....
Depends... The cheaper tyres tend to need more weights as a general rule ::)
Khumos on originally & Bridgestones fitted ....... because I wanted tyres (it's snowing & the old tyres were fubar'd) and they were available- but £470 for two tyres wasn't cheap  :'(  :'(
Quote from: cem on 18 January 2013, 18:39:14......
use another tyre shop that knows the job..   :y
Done by the very same place that would relieve you £638.41 for a 'B service'  ??? ;)
Quote from: Andy B on 18 January 2013, 18:44:26
any tyre asking for more than 40 grs is a problem.. either the wheel has a problem or the tyre needs turning..  in rare cases cheapo brands my need more than 50 grs :-\
I bet tyre is not seated properly..
Quote from: cem on 18 January 2013, 18:50:15
Thanks Cem. I'll ring them tomorrow & see what they have to say.  ;)
Quote from: Andy B on 18 January 2013, 18:52:00
just talked to a tyre shop owner (which I decided to work with him after trying more than 20 recommended shops) he agreed with me.. good brands max 40-45 gr.. chineese brands sometimes needs 60-70 grs.. but these tyres are faullty he said..
Quote from: cem on 18 January 2013, 19:12:57
Thanks again .......
Omegatoy
Andy, next time you look at the amount of weights check where they are, a poorly trained or a person with  no training will often "counterbalance" a new tyre,seen it loads of times,when you have been trained or taught properly, you learn how to sort it, when its counterbalanced you end up putting loads of weight on it!!
brief expalanation of counterbalancing,you spun the wheel up and it told you to put 25g of weight opposite the valve, so you do it and then spin it up again,it now tells you to put 10gr of weights right by the valve, spin up again and because its moved the dynamics it now tells you to put 10 gr of weight in the middle of the two previous weights! this can go on about 3 or 4 times before the machine says its balanced!
Quote from: Omegatoy on 18 January 2013, 19:39:32
All these weights are close to the valve .....  ???
henryd
Quote from: Andy B on 18 January 2013, 18:42:57
Christ,what size are they ? ???
other rides
SMD
 :o  I'm having trouble parting with £440 for 4 tyres
Omegatoy
Quote from: Andy B on 18 January 2013, 20:14:03
would guess "if the tyre is correctly seated "that you have an egg shaped wheel then mate,or a bad new tyre!!
tyre not properly seated or he was lazy to correct the wheel problem..  in snowy days tyre shops are so crowded that balancers become exhausted and sometimes want to quit the job or finish it quickly.. :-\
Quote from: henryd on 18 January 2013, 20:50:01
255/55/19 W rated
Quote from: SMD on 18 January 2013, 20:56:02
Believe me, it hurt!  :'(
I also could do with a pair for the back of my Omega
and a pair for the caravan  ??? ::) ::) ::)
Quote from: cem on 18 January 2013, 21:17:00....
Done at the dealers, so they don't have that excuse.
Quote from: Omegatoy on 18 January 2013, 20:59:25.....
I'll see what they have to say tomorrow.
thanks to you both. ;)
