F/S Estate LPG donut tank update + raised floor to increase fill (with PICs)
Started by Cliffo B, 20 January 2013, 16:06:45
doz
I'd just like to add doing business with Cliff was completely painless. Cliff is an perfect gentleman to deal with good communication throughout.  :y
Cliffo B
It's a donut tank as per the subject title
Set horizontal in the spare wheel well
As I recall the tanks were availabee in groups sized by diameter
From the particular group that suited miggy's well diameter I simply chose the deepest one made
This turned out to be about 3" higher than the floor level
Hence  why I had to raise the floor level
I do have the makers spec certificate (Polish) with English sub- titles
The height is given as 270mm
The diameter as 650mm
Capacity  76 (would consider Ltrs but nothing Quoted)
Also it is a 4 hole spec
I understand this to be far better  than a single hole multivalve install
The tank comes with all the necessary valves guages etc installed in the vapour box by myself
I'll try and post a pic showing the tank
Cliffo B
Cliffo B
Cliffo B
Hope these pics answer some of your queries
Please note they were taken pre tank install
No connections made or final fix
but give a good  idea of tank size
Cliffo B
Hi all :y
Now have to say the rear end kit is no longer available
Could Admins please remove S.A.P. :y :y
Especially as my attempt at pic management proved to be a disaster :o :-[ :-[
Going to take further tuition next week 8) ::)
