Author Topic: CCR 2006 Blank Screen  (Read 8048 times)
Rog
Re: CCR 2006 Blank Screen
« Reply #15 on: 07 May 2013, 13:31:19 »
Update: TB and others had a go at it at the High Wycombe meet, still would not come out. So, used some brute force, fascia broke off and out it came with help from some hefty pliers. There's some comfort in knowing that others also failed not just me !
Unit is now almost certainly completely knackered, but it was no use anyway. I got given (yes given!) another unit (thanks Ben!), but completely untested, with a possible code, and almost certainly not Bose enabled. Not tried fitting it yet, I want to use some lubricant to make sure I can get it out again if I should need to. If it works, then I will need to see if it can be Bose'd
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #16 on: 07 May 2013, 18:59:21 »
I had similar issues getting my unit out too, and had to repair the fascia  :-[
When refitting I removed the locking plates from the side of the unit to allow easier removal while testing  :y
Rog
« Reply #17 on: 07 May 2013, 20:32:50 »
I wondered about that. I'm a bit concerned that If I slide in another unit, I'll get the same situation in not being able to get it out again. Might try the same.
Rog
« Reply #18 on: 10 May 2013, 18:12:58 »
CCR 2006 BOSE in a 200 X Reg 2.5 V6 Elite
Everything fine with unit switched off. But when switched on radio & CD all works ok but no details on screen display, just empty.
I've been termpted to disconnect from power and have code ready, but what if screen is the same and I can't enter codes ?
Any ideas out there ?
A while back unit was sent to Dave DVD to sort the "CD Safe" issue, been fine since then but this happened out of the blue.
So . . . the saga continues
Unit got stuck, ended up wrecking it to get it out.
Got given another complete CCR2006, Removed retaining clips in case this one got stuck
Slide it in and . . . . . exactly the same as the original  >:(
With unit off the screen is completely 100% as normal. Switch unit on and where you would normally see the radio station, or CD details, its just nothing. The time etc still shows. Switch unit off everything as normal again.  Grrrrrrrrrrrrrrrrrr. I emphasize, this is a different CCR 2006 unit.
« Reply #19 on: 10 May 2013, 18:47:39 »
OK, you need to check the continuity on the 3 (or is it 4) wires between HU and screen.
Rog
« Reply #20 on: 10 May 2013, 21:52:11 »
Jamie, sorry but I know that many out there are serious techies, but just what does that mean in English. And why does it work, and then NOT work ? What's changed ? Does a wire suddenly become incomplete on it's own ?
Although this car generally is pretty damned good now I have a serious feeling that I am going to end up almost dumping it because . . . . . . the sound system doesn't work. Not good when everything else is ok.
Simon.rose1
  • Walsall
    • Omega 2.5v6 cdx
« Reply #21 on: 11 May 2013, 16:55:52 »
This might be a silly question but the bulb behind that part of the display hadn't gone has it as had them go on the vec and if you put a torch up to it you can see the figures if they working
« Reply #22 on: 12 May 2013, 09:33:59 »
The other lines are OK, so not bulbs (MIDs will still display even if only 1 bulb is working)
« Reply #23 on: 12 May 2013, 09:38:13 »
Hmmm, 2 options I see, either measure the continuity between HU and screen, or try a replacement MID.  How far are you from me?
Rog
« Reply #24 on: 13 May 2013, 14:05:09 »
Thanks TB, North London so not so far. However, I've just bought an MV6, and probably I will be putting this car as it is in the "For Sale" section soon.
